About the REVCLOUD
About the REVCLOUD
WeTanks
Mentor Mentor
About the REVCLOUD
WeTanks
I have two clouds of LISP, PLL and PLL2.
When I run the PLL, there is no such prompt as below,
Reverse direction [Yes/No] <No>:
However, when I run PLL2, there is this prompt.
I don't want PLL2 to have such a prompt, what should I do?
(defun c:PLL ()
  (command-s ".-LAYER" "_N" "PLL" "_C" "240" "PLL" "")
  (command-s "._REVCLOUD" "_A" 5 5 "_O" pause "_N")
  (command-s "._CHANGE" (entlast) "" "_P" "_LA" "PLL" "")
  (princ)
(defun c:PLL2 (/ width)
  (setq default-width 5)
  (setq width (getint (strcat "\nEnter width [" (itoa default-width) "]: ")))
  (if (null width)
    (setq width default-width)
  (command-s "._REVCLOUD" "_A" width width "_O" "pause" "_N")
  (princ)
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
komondormrex
use "pause" without quotes in pll2
