About presspull
About presspull
saitoib
About presspull
saitoib
Hi all.
command rectang 0,0 100,100
With the squares drawn, I get
In test1, I can successfully extrude it, but in test2, I get an error.
Why is this?
Please help me.
(defun c:test1 (/ th id vrs cent)
	(setq th 5)
	(setq id (car (entsel)))
	(setq vrs (vl-remove-if '(lambda (x) (/= (car x) 10)) (entget id)))
	(setq cent (mapcar '/ (list (apply '+ (mapcar 'cadr vrs))
			(apply '+ (mapcar 'caddr vrs)))
			(list (length vrs) (length vrs))))
	(setq cent (list (car cent) (cadr cent) 0.0))
	(command "_.presspull" cent th "")
(defun c:test2
	( / th pt1 pt2 ss nn i id vrs cent)
	(setq th 5)
	(setq pt1 (getpoint "\nSelect area : "))
	(setq pt2 (getcorner pt1 "\nAnother corner :"))
	(setq ss (ssget "_C" pt1 pt2(list (cons 0 "LWPOLYLINE"))))
	(setq nn (sslength ss))
	(setq i 0)
	(while (< i nn)
		(setq id (ssname ss i))
		(setq i ( 1+ i))
Saitoib
hak_vz
@saitoib  Replace command PRESSPULL with command EXTRUDE. Create selection set of lwpolylines, and apply command with appropriate extrusion length. You don't  need to search for shape center point. Positive extrude length will create 3dsolid in direction of plane normal vector, and negative in opposite.
Miljenko Hatlak
saitoib
 @hak_vz
In fact, I want to draw some separate shape inside the square and make this a hole.
This is not easy to do in AutoCAD's extrude, is it?
So I want to use presspull.
Thank you.
Saitoib
saitoib
In the case of test2
"Click inside a surface, curve, or bounding area"
message appears.
Does this mean that it can't click inside the boundary correctly?
But if I insert
(command "circle" cent 10)
I can draw a circle.
Why does ?
Saitoib
saitoib
I finally understood the cause.
In the case of test1, the effect of entsel was still there, so I was able to select it.
When presspull is in the "Select object or bounding area" state, is it possible to select the object with the command?
On the other hand, the extrude command seems to be able to use entity names, so I guess I have to use exturde even if it requires more steps?
Saitoib
