About leader command
saitoib
saitoib
Hi all.
Thank you again for your help.
The leader command is completed by specifying the starting point, the next point, and then typing "A" and the text.
Is it possible to use AutoLisp to specify the coordinates at the start point, click the mouse at the next point, type "A", enter text, and pass the text variable?
Thank you.
Saitoib
devitg
@saitoib
try it
(SETQ PT1 '(0 0 0))
(SETQ TEXT "text to leader")
(SETQ OSMODE (GETVAR 'OSMODE))
(SETVAR 'OSMODE 0)
(VL-CMDF "leader" PT1 PAUSE "A" TEXT "")
(SETVAR 'OSMODE OSMODE)
saitoib
@devitg
PAUSE, huh?
I've solved it.
Thank you very much.
Saitoib
ronjonp
You can also use "\\" it's a bit more consistent since pause could be redefined by a rogue routine.
