A simple lesson for changing the properties of objects inside blocks
I'm trying dilligently to learn how to code in AutoLISP for changing things like layer assignments of objects inside blocks.
I've been looking at examples for a while now, and it's too much for me to take in all at once.  Please note the following code:
; Changes selected objects to Layer TO_THIS_LAYER
(defun c:TTL ()
(tolayer
(ssget "_:L") ;;selection
"TO_THIS_LAYER" ;;Layer
(princ)
I need to get to the next step: being able to make this kind of object property assignment change inside a block without opening the block editor every time.  I know it involves a few "vla--" commands.  Could someone format this simple program for me so I have a good, basic example to learn from?  Also is it possible to retain the object-selection-highlighting, or is that not possible when reaching directly into a block for edits? Thanks in advance!
jdiala
Here is a quickie
(defun C:test (/ ss e blk doc)
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(if
  (setq ss (ssget ":L" '((0 . "INSERT"))))
  (repeat (setq i (sslength ss))
     (setq e (vlax-ename->vla-object (ssname ss (setq i (1- i)))))
     (setq blk (vla-item (vla-get-blocks doc) (vla-get-Effectivename e)))
     (vlax-for x blk
       (vla-put-layer x "MDUCT");your layer here
(vla-regen doc acAllViewports)
(princ)
GREAT!  Thanks so much! Smiley HappySmiley Very Happy
...OOPS, except it's changing everything inside the block, not just the single entity I pick.  Any chance of modifying your code for that?  My blocks have different lines inside them that need differing layer assignments.  Thanks!
jdiala
(defun C:test (/ ss e blk doc lay)
      lay "MDUCT") ;set your layer here
(if
     (vla-put-layer e lay)
     (vlax-for x blk
       (vla-put-layer x lay)
(princ)
jdiala
Sorry my bad. Misunderstood your request the last time. Here you go.
(defun C:test ()
(vla-put-layer (vlax-ename->vla-object (car (nentsel))) "MDUCT")
(vla-regen (vla-get-activedocument (vlax-get-acad-object)) acAllViewports)
