A polyline over another polyline segment
there are a way to draw a polyline over a segment of another polyline? I would like to draw a polyline of a vertex X until vertex Y and then go to another direction. I think that a way to copy only a segment without explode all the polyline will work too.
john.uhden
I made an XOFFSET command that will offset or clone polyline segments even if nested in a block or xref, but I've never thought about continuing the new entity.
John F. Uhden
Kent1Cooper
Just have ENDpoint Object Snap among your running Osnap modes, and you can snap to vertices as you draw the new Polyline.
Kent Cooper, AIA
john.uhden
You had better add midpoint for bulged segments.
John F. Uhden
CodeDing
@Anonymous ,
This will work on PLines WITHOUT bulges (i need more practice to handle that), I think this is close to what you might be looking for:
(defun c:OPL ( / e eg MultiAssoc pList p1 p2)
  (if (and (setq e (car (entsel "\nSelect Polyline: ")))
           (eq "LWPOLYLINE" (cdr (assoc 0 (setq eg (entget e))))))
    (progn
      (setq MultiAssoc (lambda (k l / i) (if (setq i (assoc k l)) (cons (cdr i) (MultiAssoc k (cdr (member i l)))))))
      (setq pList (MultiAssoc 10 eg))
      (while (not p1)
        (initget 1) (setq p1 (getpoint "\nSelect 1st Vertex on PLine: "))
        (setq p1 (reverse (cdr (reverse p1))))
        (setq p1 (member p1 pList))
      );while
      (while (not p2)
        (initget 1) (setq p2 (getpoint "\nSelect 2nd Vertex on PLine: "))
        (setq p2 (reverse (cdr (reverse p2))))
        (setq p2 (member p2 pList))
      );while
      (if (< (length p1) (length p2))
        (setq pList (member (car p1) (reverse p2)))
        (setq pList (reverse (member (car p2) (reverse p1))))
      );if
      (setq pList
        (cons
          "_.PLINE"
          (apply 'append (mapcar '(lambda (p) (list "non" p)) pList))
        );cons
      );setq
      ;execute final command
      (apply 'command-s pList)
    );progn
  );if
  (princ)
);defun
Best,
~DD
Thank you very much! It is exactly what I need.
diagodose2009
Eu folosec programul pp_imprejmure.vlx,  pentru a determina(found) intersectiile, rotatiile vertexilor,
vertexill-multplicatii in desen.Eu setez "CircleRad" 0.1. si eu tastez Q2[enter]
For  checking, segment, intersection of polylines, or you need verifying polylines,
you must pp_pimrejmuire.vlx
