A lisp to load Layer and line types.
3arizona
3arizona
I have this lisp that loads layers, a line type "Hidden2" and sets text style to MS REFERENCE SANS SERIF.  Everything works but when done last layer (60) line type changes to Hidden2.
I want lisp to finish like this:
  • load layers
  • load line type(s)
  • set text style
  • change back to previous layer
Lisp:
(defun c:TEST1()
(setq oldlay (getvar "clayer"))
(COMMAND "-LAYER" "M" "8" "C" "8" "" "")
(COMMAND "-LAYER" "M" "5" "C" "2" "" "")
(COMMAND "-LAYER" "M" "15" "C" "3" "" "")
(COMMAND "-LAYER" "M" "10" "C" "4" "" "")
(COMMAND "-LAYER" "M" "60" "C" "5" "" "")
(COMMAND "-LAYER" "l" "hidden2" "" "")
(COMMAND "-style" "standard" "MS REFERENCE SANS SERIF" "0" "1" "0" "n" "n")
(setvar "clayer" oldlay))
(prin1)
rkmcswain
Maybe this?
(defun c:TEST1( / oldlay expert)
  (setq expert (getvar "expert"))
  (setvar "expert" 3)
  (vl-cmdf "linetype" "load" "hidden2" "acad.lin" "")
  (setvar "expert" expert)
  (princ)
R.K. McSwain     | CADpanacea | on twitter
john.uhden
Well that's what you programmed it to do.
(COMMAND "-LAYER" "l" "hidden2" "" "") ;; sets the linetype "hidden2" for the current layer, which you just made "60" in the line before,
I am wondering if you really wanted to
(command "-ltype" "Load" "hidden2")
John F. Uhden
3arizona
rkmcswain
this is what i was looking for.  Thank you, for your time!
