A lisp program about changing linetypes
Message 1 of 10
I was wondering if there was a possible program that could change the linetype of a drawing but have the appearance of all the other lines remain constant. (the linetype of those lines does not matter). I have been experimenting with msltscale, but have found that when I turn that off and regenerate the program the lines return to their previous scale, any ideas? I'm relatively new to AutoCAD (2016 version), so anything helps.
Replies (9)
Message 2 of 10
@Anonymous I do not understand you.
SELECTSIMILAR on all lines and Change PROPERTIES, Not working?
Please post an example of your .dwg explaining better.
Message 3 of 10
It's not a specific drawing that I'm working on. I'm trying to change the LTscale for any drawing and have the lines change linetype scale accordingly. For example, say a line has a scale of 16 and my global ltscale is 1. I want to change my global ltscale to 2 and have my line look the same. When i change the global ltscale from 1 to 2, the linetype scale of the line stays 16 but actually resembles 32. So what I'm trying to do is select all lines and divide by the new scale so they will look the same when the global ltscale is changed if that makes sense.
Message 4 of 10
I've reread my first message and meant to add "scale" after linetype, i see why you were confused, my mistake.
Message 5 of 10
@Anonymous Something like ?
(defun c:Demo (/ ss id ls)
  (setq ss (ssget "_X" '((0 . "LINE")))
	id 0)
  (setq ls (getreal "\nNew Scale: "))
  (repeat
    (sslength ss)
    (command "_.Chprop" ss "" "ltScale" ls "")
    (setq id (1+ id))
  (princ)
Message 6 of 10
Very close to that! Instead of changing the linetype scales of all lines to the new linetype scale, is there a way to divide them by the new linetype scale instead?
Message 7 of 10
A simple way to do this is to add one more in the ssget (48 . 0.1) change the pink text to the scale of your line. so the program will only select lines from this scale.
  (setq ss (ssget "_X" '((0 . "LINE")(48 . 0.1)))
	id 0)
  (repeat
    (sslength ss)
    (setq id (1+ id))
  (princ)
"Accept as Solution" if it has solved the problem.
Message 8 of 10
That's perfect, thank you! I was having trouble getting the selection sets.
Best!
Message 9 of 10
Sorry. @Anonymous
unnecessary variable!
(defun c:Demo1 (/ ss ls)
  (setq ss (ssget "_X" '((0 . "LINE")(48 . 0.1))))
  (repeat
    (sslength ss)
  (princ)
Message 10 of 10
That's fine! you've been a great help! Is there anyway we could replace the 0.1 with a variable that checks all numbers from 1 to 100 instead of just 0.1?
