A handy LISP routine to delete all white hatching (equal to colour number 7 or 255)
MaccyDee
Message 1 of 11
MaccyDee
A handy LISP routine that will delete all white hatching equal to colour number 7 or 255.
it was taking me too long to open drawings and delete large white hatched areas using traditional methods so i just thought id share this lisp i wrote the other day for deleting all hatching of a particular colour in the dwg, it can be easily modified to change or add colours.
any questions feel free to ask!
" (defun c:dwh ()
(vl-load-com) ; load the Visual LISP ActiveX interface
(setq ss (ssget "X" '((0 . "HATCH")))) ; select all hatches in the drawing
(if ss ; if the selection set is not nil
(progn ; do the following
(setq i 0) ; initialize a counter
(repeat (sslength ss) ; loop through the selection set
(setq ent (vlax-ename->vla-object (ssname ss i))) ; get the hatch object
(if (or (= (vla-get-Color ent) 7) ; if the hatch color is white
(= (vla-get-Color ent) 255) ; or if the hatch color is 255
) ; end or
(vla-delete ent) ; delete the hatch object
) ; end if
(setq i (1+ i)) ; increment the counter
) ; end repeat
) ; end progn
) ; end if
(princ) ; exit quietly
) ; end defun "
Replies (10)
Message 2 of 11
paullimapa
nice start...comments:
entdel will not succeed if hatch object is on a locked layer
hatches inside blocks will not be accounted for
Paul Li
IT Specialist
@The Office
Message 3 of 11
MaccyDee
I didn't want it to affect locked layers or blocks, sometimes columns are white hatched and i lock these before i do anything else, as for blocks i have a lisp routine called DOIB (delete objects in blocks) which works really well for any objects in blocks, ill attach for reference
Message 4 of 11
paullimapa
that's a nice lisp routine to be able to specify what kind of objects to delete inside a block
Paul Li
IT Specialist
@The Office
Message 5 of 11
Sea-Haven
Just one comment 7 is not the same as 255, change your screen color background, one is black the other is white. Hope you can see one line is black the other is white.
Message 6 of 11
Kent1Cooper
That accounts for Hatches that are color 7 or 255 by color property override only.  Should it be expanded to include any that are color ByLayer on Layers that have those colors?
Kent Cooper, AIA
Message 7 of 11
MaccyDee
for our setup (black background) any black colors aside from 255 are set to display as white, if youre using this routine for yourself, its straight forward to open with txt editor and remove the line or change the number to something else
Message 8 of 11
MaccyDee
that's a good point, ill get onto that!
Message 9 of 11
MaccyDee
alright ive given it a go,
(defun c:delhatch ()
(if (= (vla-get-Color ent) 256) ; if the hatch color is bylayer
(setq layerObj (vla-item
(vla-get-Layers
(vla-get-ActiveDocument
(vlax-get-acad-object)
(vla-get-Layer ent)
)) ; get the layer object of the hatch
;; check if the layer is locked using DXF code 70
;; if it is locked, skip to the next object using continue
(if (= (logand (cdr (assoc 70 layerObj)) 4) 4) ; if the layer is locked
(continue) ; skip to the next object
;; else, check if the layer color is index colour 7, 8 or 255 and delete the hatch object if true
(if (or (= (vla-get-Color layerObj) 7) ; if the layer color is index colour 7
(= (vla-get-Color layerObj) 😎 ; or if the layer color is index colour 8
(= (vla-get-Color layerObj) 255) ; or if the layer color is index colour 255
) ; end or
) ; end if
) ; end if
) ; end progn
;; else, check if the hatch color is index colour 7, 8 or 255 and delete the hatch object if true
(if (or (= (vla-get-Color ent) 7) ; if the hatch color is index colour 7
(= (vla-get-Color ent) 😎 ; or if the hatch color is index colour 8
(= (vla-get-Color ent) 255) ; or if the hatch color is index colour 255
) ; end or
) ; end if
) ; end if
) ; end repeat
) ; end progn
) ; end if
) ; end defun
but I feel this is a bit clunky, I'm not very good at lisp..
this occasionally will result in an error that says "error: bad argument type: listp #<VLA-OBJECT IAcadLayer 000001ec2eeb0808>" but its only doing it on some drawings, the others seem to be working as intended
my test file is attached, also i cant get the emoji to not appear but the characters are meant to be "8_)" no underscore (_)  8)8)8)8)
Message 10 of 11
Kent1Cooper
@MaccyDee wrote:
.... i cant get the emoji to not appear but the characters are meant to be "8_)" no underscore (_)  8)8)8)8)
Theoretically, you should be able to put it in a code window [pick on the </> in the toolbar] to prevent that:
(= (vla-get-Color layerObj)  ; or if the layer color is index colour 8
) ; end or
) ; end if
) ; end if
) ; end progn
(= (vla-get-Color ent)  ; or if the hatch color is index colour 8
but that doesn't work, either [no smiley, but no 8 and ) either].  If you're aware of the issue as you post things, put a space between the 8 and the ).
Kent Cooper, AIA
Message 11 of 11
Kent1Cooper
@MaccyDee wrote:
.... this occasionally will result in an error that says "error: bad argument type: listp #<VLA-OBJECT IAcadLayer 000001ec2eeb0808>" ....
Does that problem occur only with locked Layers, which might explain why it occurs only in some drawings?  I ask because for those, you call for a (continue) function, but you didn't include the definition of that.
Kent Cooper, AIA
