3d polyline vertices
I would like to obtain all of the vertices on a given 3DPolyline. I can get to the point where I have a list with the (100 . "AcDb3dPolyline") , but do not know where or what to do after that point.
Can someone give me a little push to let me know where i may find this information from?
_gile
Here're two ways.
Using DXF codes vertices are sub entities of the 3dpoly, have to use (entnext ...)
(setq poly (car (entsel)))
(setq vtx (entnext poly))
(while (/= (cdr (assoc 0 (setq elst (entget vtx)))) "SEQEND")
(setq lst (cons (cdr (assoc 10 elst)) lst)
vtx (entnext vtx)
(reverse lst)
Another way using VisualLISP
(vl-load-com)
;; Split a flat list into a points list
(defun 3d-coord->pt-lst (lst)
(if lst
(cons (list (car lst) (cadr lst) (caddr lst))
(3d-coord->pt-lst (cdddr lst))
(setq lst (3d-coord->pt-lst (vlax-get (vlax-ename->vla-object poly) 'Coordinates)))
Gilles Chanteau
GileCAD
GitHub
Thanks gile!!
I appreciate your help and time...Its been a while for me writing some lisp...
Thanks again!
