3 Filter selection Text Objects
k005
Advisor Advisor
k005
Hello friends;
How can I select the L=196 text object with a filter when I click it?
There should be 3 filters.
1- Color
2- content ( L=196)
3- Text height
Thanks.
hak_vz
(setq ss (ssget '((0 . "TEXT") (1 . "L=196") (62 . 1) (40 . 5))))
This will create selection set of selected text with content L = 196, color red and height 5 units
Change color according to index color numbers.
To select all similar text use selection mode string "X"
(setq ss (ssget "X" '((0 . "TEXT") (1 . "L=196") (62 . 1) (40 . 5))))
To use in command line let say erase:
Command: ERASE
Select objects: !ss
<Selection set: 43>
2 found
Miljenko Hatlak
k005
@hak_vz
It will perform this operation automatically when I select the text object and confirm it. ie parameters-filters will be selected by itself.
"2nd". condition is not always fixed...
pbejse
1- Color 2- content ( L=196) 3- Text height
(defun c:demo (/ source ent data ss)
  (and
    (setq source (car (entsel "\nSelect Text source: ")))
    (eq (cdr (assoc 0 (setq ent (entget source)))) "TEXT")
    (setq data (mapcar '(lambda	(d)
			  (assoc d ent)
		       '(62 0 1 40)
    (sssetfirst
      nil
      (ssget "_X"
	     (if (car data)
	       data
	       (cons '(62 . 256) (Cdr data))
HTH
k005
@pbejse
Thank you my friend. It's ok. 🤗
ronjonp
Here's my version 🤓
