This did NOT happen in 2013. I have a lisp that is create a string of text based on numerous variables in the drawing, that when I write the code to use the "-insert" command, it would generate a text for me.
Now in 2014, the "Enter Attribute" dialogue box appears, an the user has to type in the information manually. There must be a variable to trun this off to go back to the 2013 way.
Variable ATTREQ to "0" is not the answer in this case.
