100cm and bigger
100cm and bigger
k005
Advisor Advisor
Message 1 of 43
100cm and bigger
k005
Hello guys;
How can I calculate the area of column sizes of 100 cm and above?
* The number 260 will be entered manually. example is attached.
* We will make the color of the relevant parts green.
Thanks.
Accepted solutions (4)
Replies (42)
Message 2 of 43
hak_vz
@k005You are not new to this forum, so please, to help us create your script attach sample dwg.
Miljenko Hatlak
Message 3 of 43
k005
Sorry.
Message 4 of 43
hak_vz
Try this
(defun c:area_100+ ( / ss i con sumlist mult);
(princ "\nSelect all columns text >")
(setq ss (ssget '((0 . "TEXT") (8 . "Kolon"))) i -1)
(while (< (setq i (1+ i)) (sslength ss))
	(setq con (cdr (assoc 1 (entget(ssname ss i)))))
	(setq con (substr con (+(vl-string-position (ascii "(")con)2)))
	(setq con (substr con 1 (vl-string-position (ascii "/")con)))
	(setq con (atof con))
	(cond ((>= con 100.0)(setq sumlist (cons con sumlist))))
(cond
	((and sumlist)
		(setq mult (getreal "\nEnter multiplicator >"))
		(princ (strcat "\nLengths: "(vl-princ-to-string sumlist) "\n"))
		(princ (strcat "Total area = " (rtos (* mult (apply '+ sumlist)) 2 2)))
	(T (princ "\nNo column > 100 "))
(princ)
Miljenko Hatlak
Message 5 of 43
k005
* a fix: for attached file
Not 6.45 m², correct calculation: It should be 10.53 m². I made a mistake...
@hak_vz
Good luck my friend. yes, that's exactly it. if it can change the selected columns to green color. It'll be super. It's not much of a problem...
Message 6 of 43
hak_vz
This will change column text to green. Multiplier is entered in centimeters, result is expressed in m2. For your test sample it gives 10.53. Code was edited so take last version.
	(cond
		((>= con 100.0)
			(setq sumlist (cons (* 0.01 con) sumlist))
			(vlax-put (vlax-ename->vla-object (ssname ss i)) 'Color 3)
(cond
	((and sumlist)
		(setq mult (getreal "\nEnter multiplier >"))
		(princ (strcat "Total area = " (rtos (* 0.01 mult (apply '+ sumlist)) 2 2) " m2"))
(princ)
Miljenko Hatlak
Message 7 of 43
k005
@hak_vz
Thank you very much. It's ok. 🤗
Message 8 of 43
pbejse
(defun c:Demo ( / tData Total Strng ss ml pt i str)
(if   (and
     (setq Total 0 strng ""
	  ss (ssget '((0 . "TEXT") (8 . "KOLON")(1 . "*(###/#*)"))))
      (setq ml (getreal "\nEnter factor: "))
      (setq pt (getpoint "\nPick point for Total: "))
   (progn
     (repeat (setq i (sslength ss))
       (setq str (cdr (assoc 1 (setq ent (entget  (ssname ss (setq i (1- i))))))))
       	  (setq str (atoi (substr str (+ 2 (vl-string-position 40 str  nil t))))
		Total (+ Total str)
		strng (strcat "+" (itoa str) strng)
       (entmod (append ent '((62 . 3))))
       (or tData (setq tData (mapcar '(lambda (d)
			(assoc d ent))'(0 7 8 62 40 50))))
        (entmakex (append  tData
			  (list '(62 . 3)(cons 10 pt)
				(cons 1 (strcat "ALAN: (" (substr strng 2) ")x"
							 (rtos ml) " = "
							 (rtos (* 0.0001 Total ml) 2 2) " m²")))))
	  )(princ)
HTH
Message 9 of 43
k005
@pbejse
I'm adding this solution to my Archive. Thank you very much. 🤗
Message 10 of 43
k005
@pbejse
@hak_vz
Friends; Can we do this in line or lwpolyline version instead of text?
Message 11 of 43
hak_vz
@k005  Please explain in details
Miljenko Hatlak
Message 12 of 43
k005
@hak_vz
Message 13 of 43
hak_vz
In other words, select all rectangles that have a edge longer than 100, and set its color to green?
Miljenko Hatlak
Message 14 of 43
k005
Yes. including 100
Message 15 of 43
hak_vz
(defun c:rect_side_greather_than ( / adoc edge_length ss i j  pointlist2d take eo pointset lenghts *error*)
	(defun *error* ( msg )
		(if (not (member msg '("Function cancelled" "quit / exit abort")))
			(princ)
		(if (and adoc) (vla-endundomark adoc))
		(princ)
	(defun pointlist2d (lst / ret) (while lst (setq	ret (cons (take 2 lst) ret) lst (cddr lst))) (reverse ret))
	(defun take (amount lst / ret)(repeat amount (setq ret (cons (car lst) (take (1- amount) (cdr lst))))))
	(setq edge_length (getreal "\Enter minimal rectangle edge length >"))
	(setq ss (ssget '((0 . "LWPOLYLINE") (8 . "Kolon"))) i -1)
	(setq adoc (vla-get-activedocument (vlax-get-acad-object)))
	(vla-startundomark adoc)
		(setq eo (vlax-ename->vla-object (ssname ss i)))
		(setq pointset (pointlist2d (vlax-get eo 'Coordinates)))
		(setq pointset (append pointset (list (car pointset))))
		(setq lenghts nil j -1)
		(while (< (setq j (1+ j)) (1- (length pointset)))(setq lenghts (cons (distance (nth j pointset)(nth (1+ j) pointset)) lenghts)))
		(cond ((>= (apply 'max lenghts) edge_length) (vlax-put eo 'Color 3)))
	(princ "\nDone!")
	(princ)
In case rectangle in not closed ie, edges are polyline segments, it will put color to green only to polyline edges greater than minimal length.  If closed, rectangle will be changed to green. I would join all segmented rectangles to  one single polyline it that is not a problem for you.
Miljenko Hatlak
Message 16 of 43
k005
Yes, that's exactly it. we will also make an area account,..
Let's say we entered 260 manually, we will add the lengths of the green wings and multiply by 260, my friend.
* (setq edge_length (getreal "\Enter minimal rectangle edge length >"))
We can fix this part to 100.
Message 17 of 43
hak_vz
In other words at start you have rectangles created with polyline segments. We collect all sides greater or equal to 100
, color it green, and sum its length to total length. At the end we multiply total length to wall height. and convert to square meters. When finished you can join segments to closed polylines.
Miljenko Hatlak
Message 18 of 43
k005
Ok so far.
we have to manually enter 260, add the side lengths and calculate the AREA.
Message 19 of 43
hak_vz
Try this. Works on segmented rectangles which edge is either line or polyline.
(defun c:rect_side_greather_than_100 ( / adoc edge_length ss i eo  total total_length wall_height total_area *error*);
			(princ)
		(princ)
	(setq edge_length 100.0)
	(setq ss (ssget '((0 . "LWPOLYLINE,LINE") (8 . "Kolon"))) i -1)
	(initget 1)
	(setq wall_height (getreal "\nWall heigth >"))
		(setq len (vlax-get eo 'Length))
			(cond
				((>= len 100)
					(setq total (cons (* 0.01 len) total))
	(setq total_length (apply '+ total))
	(setq total_area (* 0.01 wall_height total_length))
	(princ (strcat "\nLengths greater than 100: "(vl-princ-to-string total) "\n"))
	(princ (strcat "\Total lenght > 100: " (rtos total_length 2 2) " m \n"))
	(princ (strcat "Total area = " (rtos total_area 2 2) " m2"))
	(princ "\nDone!")
	(princ)
Miljenko Hatlak
Message 20 of 43
k005
@hak_vz
Thank you very much my friend. It's okay with a little difference.
Let's go from the example file:
result: 21.06 m².
The result should be: 10.53 m².
ie : result / 2
If it's not too much trouble... Thank you.
