; 1 form loaded from #<editor "<Untitled-1> loading...">
spence7
Message 1 of 8
spence7
Good day.
     I am an Autocad hobbyist in my first week of learning Autolisp.
Been using Autocad for 20 something years and finally getting around to upping my game.
I found some nice tutorial videos from CSS and am trying to follow along.
is the response to         (setq eName (car (entsel "Select an object")))
and almost anything else i put in the work field.
Help              Spence Ball,       Silver Spring, MD USA
Replies (7)
Message 2 of 8
paullimapa
I'd suggest you start with this website:
AutoLISP Beginners' Tutorials | AfraLISP
Then follow along by entering the code directly into the AutoCAD command prompt
Paul Li
IT Specialist
@The Office
Message 3 of 8
komondormrex
hey,
every autolisp function/expression loaded from within vlisp ide will be considered as ONE form upon loading/interpreting UNLESS you enclosed them by defun function which will be considered as ONE form and will take a command/function status. that command/function can be then run from autocad command line.
Message 4 of 8
Sea-Haven
Maybe give us a hint of a task you would like to do, pick something simple that you do all the time, we can write the steps not the actual code, leaving that for you to do.
A good simple one is draw a rectang based on pick point, length & width.
Message 5 of 8
spence7
Dear Paul,
Hi. Thank you for the link to Afralisp.
It seems to be for children, and in terms of learning new languages I am a 6 year old.
It is perfect.
(I am actually 62 but...)
I like patient tutorials.
Message 6 of 8
spence7
Dear Sea-Haven,
The real end I am looking for is apparently a year away.
I've been using Autocad for more than 20 years as a very sophisticated primitive.
That is,,, I can make 60 elaborate plates of stuff for my boss to manufacture in 8 days.
I am mostly looking to up my game because I am bored with the simple jobs I do every day.
I am also a bit thick, and learning a new language comes very slowly.
Any way... "More will be revealed".
Thanks for listening.
Message 7 of 8
paullimapa
You are very welcome. We all have a humble beginning. But if you continue to learn soon you’ll graduate and become a professional programmer
Paul Li
IT Specialist
@The Office
Message 8 of 8
Sea-Haven
Any chance of a sample dwg then  we can make suggestions about automation.
