Try this one and let me know. Just load and use as follow by typing something like this on command prompt:
(comma 123456.123 2) then you get 123,456.12
or
(comma 123456.123 0) then you get 123,456
The 1st set of number is to number to add commas to, the 2nd is the precision #. This may be used as a function also and add to your existing lisp routines.
Enjoy !
;;Function to Add Thousand comma separator to any number
;;By Felix P. Godoy
;;03/10/2004
;;revs. 04/46/2005 Clean up / More efficent
(defun comma ( Numb )
(setq lenNumb 0)
(setq lenwhole 0)
(setq lenNumb 0)
(setq decpos 0)
;(setq rBlock3 nil)
;(setq rBlock3cl nil)
(setq dunits (getvar "dimunit"))
(setq Number nil)
(setq FinalNumber nil)
(setq FoundE nil)
(setq NumberList nil)
(setq wholeList nil)
(setq rwholeList nil)
(setq strNumb (rtos Numb 2 dunits))
(setq FoundE (vl-string-search "E+" strnumb))
(setq lenNumb (strlen strNumb))
(setq decpos (vl-string-position 46 strNumb))
(if (null decpos)
(setq decpos 16)
(setq redFactor (- lenNumb decpos))
(setq wholeNumb (substr strNumb 1 decpos))
(setq wholeList (vl-string->list wholeNumb))
(setq rwholeList (reverse wholeList))
(setq rwholeNumb (vl-list->string rwholeList))
(setq lenwhole (strlen wholeNumb))
(setq startn 1)
(if (or (<= lenwhole 3) (= FoundE T))
(setq FinalNumber strNumb)
(progn
(while (/= "" rBlock3)
(setq rBlock3 (substr rwholenumb startn 3))
(setq rBlock3c (strcat rBlock3 ","))
(setq rBlock3cl (vl-string->list rBlock3c))
(if (/= rBlock3cl nil)
(setq NumberList (append (reverse rblock3cl) NumberList))
(setq Number (vl-list->string NumberList))
(setq FinalNumber (vl-string-left-trim ",," Number))
(setq startn (+ startn 3))
);progn
);if
(princ)
);defun
; Reverses a string
(defun revs ( string )
(vl-list->string (reverse (vl-string->list string)))
It's not returning anything for me -- not nil, not an empty text string, just nothing. Also, your usage examples show giving it two arguments, but it's written for only one, and when I paste your examples in, it confirms that I've given it too many arguments.
You could also do it like this, which would be called by typing "rtoc" into cad, followed by the number you wish to pad and the # of decimal places beyond the number you wish to have trailing
(defun C:rtoc (/ num # p#) (setq num (getreal "Input number to pad:")) (setq # (getint "Precision (amount):")) (setq num (rtos num 2 #) # 1) (while (and (/= (substr num # 1) ".")(<= # (strlen num))) (setq # (1+ #)) ) (setq # (1- #) p# #) (if (= (setq # (rem # 3)) 0)(setq # 3)) (while (< # p#) (setq num (strcat (substr num 1 #) "," (substr num (1+ #))) # (+ 4 #) p# (1+ p#) ) ) num )
Minimally tested, uses getreal but I did not test if letters were inputted instead of numbers...common sense and an understanding of the english language required!
HTH
Try to use this instead
;;By Felix P. Godoy 03/10/2004
;;revs. 04/16/2005 Adds thosands comma separator to any number/ Clean up / More efficient
;; Numb = any number
;; Prec = precision
(defun comma ( Numb Prec / lenNumb lenwhole decpos rBlock3 rBlock3c rblock3cl Mode Number NumberList FinalNumber FoundE Found- wholelist rwholelist wholeNumb rwholeNumb afterdec strNumb redFactor startn commaNumber)
(setq lenNumb 0)
(setq lenwhole 0)
(setq decpos 0)
(setq rBlock3 nil)
(setq Mode (getvar "dimunit"))
(setq Number nil)
(setq FoundE nil)
(setq Found- nil)
(setq strNumb (rtos Numb Mode Prec))
(setq Found- (vl-string-search "-" strnumb))
(if (null decpos)
(setq decpos 16)
(setq afterdec (vl-string-left-trim WholeNumb strNumb))
(setq startn 1)
(setq commaNumber strNumb)
(progn
(if (= Found- 0)
(progn
(setq FinalNumber (vl-string-left-trim ",,-," Number))
(setq commaNumber (strcat "-" FinalNumber afterdec))
(progn
(setq commaNumber (strcat FinalNumber afterdec))
);this progn
);this if
(setq commaNumber commaNumber)
);while ends
);progn
);if
);defun
; Reverses a string
@Anonymous wrote:
There are 3 things to type in parenthesis at the command prompt: (comma
number #)
1. the command: comma
2. the number to add commas to
3. the # precision
Load it by just dropping into dwg.
Now type in parenthesis something like: (this comma is w/ 2 m's)
(comma 7654321 0) then you get 7,654,321
I understand all of that, and did it all before [EDIT: with your first one (Message 5)], except that I put it into a .lsp file and APPLOADed it, rather than dropping it into the drawing. Then, pasting one of your examples directly:
Command: (comma 7654321 0)
; error: too many arguments
I haven't a clue how you're getting away with giving it two arguments, when there's only one argument item listed in the parentheses after the function name on the (defun ... line -- that's what's giving me the error message. Is what you have loaded really the same code as what you posted? I tried omitting the precision, so it would at least have the right number of arguments, and did:
Command: (comma 7654321)
That's when I got nothing at all, not nil, not an empty string, no error message, but it just went back to the Command: prompt.
EDIT: I see now that the later one does account for two arguments.
However, it has a problem for people like me who use Architectural Units, I expect because of its using the DIMUNIT System Variable for the mode argument in (rtos) functions. I get, for example:
Command: (comma 1542324.3112 3)
"12,852,7'-,0 1,/4\""
And things involving calculation can come out not as intended, like:
Command: (comma (* 123456 987675.43) 3)
"1.219E+11"
Here's the approach I took:
(defun commify (num prec / numstr intstr decstr comstr)
(setq
numstr (rtos num 2 prec); eliminates any scientific-notation E+ element
intstr ; integer portion as string
;; (itoa (fix num)) has problem with calculated returns in scientific notation,
;; so use (rtos) to 0 decimal places, but that rounds, possibly upward, so:
(if (< (- num (fix num)) 0.5)
(rtos num 2 0)
(rtos (1- num) 2 0)
); if & intstr
decstr (substr numstr (1+ (strlen intstr))); decimal portion as string ["" if no decimal places]
comstr (substr intstr 1 (rem (strlen intstr) 3)); begin commified string w/ part before first comma [if any]
intstr (substr intstr (1+ (strlen comstr)))
); setq
(while (>= (strlen intstr) 3)
(setq
comstr (strcat comstr (if (> (strlen comstr) 0) "," "") (substr intstr 1 3)); [no comma if starts with 3 digits]
intstr (substr intstr 4)
); setq
); while
(strcat comstr decstr); add decimals back [if any]
Which gives such results as:
Command: (commify 284725.86572 3)
"284,725.866"
Command: (commify 1 0)
"1"
Command: (commify 234 4)
"234.0000"
Command: (commify 95738462.4 2)
"95,738,462.40"
Command: (commify pi 10)
"3.1415926536"
Command: (commify (* 123456 987675.43) 3)
"121,934,457,886.080"
Command: (commify (expt 2.5 😎 4)
"1,525.8789"
@Anonymous wrote:
I had posted an OLD version. Did you see my new post/email?
[Yes -- we obviously "crossed in the mail" with your latest and my editing my previous reply, q.v.]
This looked like fun - here is my version:
(defun rtoc ( n p / d i l x ) (setq d (getvar 'dimzin)) (setvar 'dimzin 0) (setq l (vl-string->list (rtos n 2 p)) x (cond ((cdr (member 46 (reverse l)))) ((reverse l))) i 0 ) (setvar 'dimzin d) (vl-list->string (append (reverse (apply 'append (mapcar '(lambda ( a b ) (if (and (zerop (rem (setq i (1+ i)) 3)) b) (list a 44) (list a) ) ) x (append (cdr x) '(nil)) ) ) ) (member 46 l) ) ) )
@Kent, be careful when DIMZIN=8
Another to account for negatives:
(defun rtoc ( n p / d i l x ) (setq d (getvar 'dimzin)) (setvar 'dimzin 0) (setq l (vl-string->list (rtos (abs n) 2 p)) x (cond ((cdr (member 46 (reverse l)))) ((reverse l))) i 0 ) (setvar 'dimzin d) (vl-list->string (append (if (minusp n) '(45)) (reverse (apply 'append (mapcar '(lambda ( a b ) (if (and (zerop (rem (setq i (1+ i)) 3)) b) (list a 44) (list a) ) ) x (append (cdr x) '(nil)) ) ) ) (member 46 l) ) ) )
And a recursive variation:
(defun rtoc ( n p / foo d l ) (defun foo ( l n ) (if (or (not (cadr l)) (= 46 (cadr l))) l (if (zerop (rem n 3)) (vl-list* (car l) 44 (foo (cdr l) (1+ n))) (cons (car l) (foo (cdr l) (1+ n))) ) ) ) (setq d (getvar 'dimzin)) (setvar 'dimzin 0) (setq l (vl-string->list (rtos (abs n) 2 p))) (setvar 'dimzin d) (vl-list->string (append (if (minusp n) '(45)) (foo l (- 3 (rem (fix (/ (log (abs n)) (log 10))) 3))) ) ) )
Another
(defun _comma (n p / a b m i lst) (setq dz (getvar 'dimzin)) (setvar 'Dimzin 0) (setq str (rtos (abs n) 2 p)) (setvar 'Dimzin dz) (setq a (vl-filename-base str) b (substr str (1+ (strlen a))) m (vl-string->list a) i (length m) lst nil) (while (>= i 3) (setq lst (append (list 44 (nth (- i 3) m) (nth (- i 2) m) (nth (1- i) m)) lst ) i ( - i 3)) lst ) (strcat (if (minusp n) "-" "")(substr str 1 i) (vl-list->string (if (zerop i) (cdr lst) lst)) b))
[Not thorougly tested]
