0.4mm Break Macro
0.4mm Break Macro
0.4mm Break Macro
Hey guys, I've asked about this before, but wanted to try something a bit different, so currently at work I'm using Auto Cad to create designs to be laser cut into MDF, doing so I need to add 0.4mm tabs to the designs so they hold to the sheet. Currently I'm using the Break function and inserting the desired distance of the break, but I have to repeat this many times for each component. I was wondering if there was a way to possible create a Macro that's assigned to the extra buttons on my mouse to automatically insert the desired break each time I press it.
How would I go about doing this?
Thanks for any help you can give
ВeekeeCZ
It would be nice of you if you go back to your previous thread and mark it solved - so we know what routine you're using now. Also, you can tell us how you run in.
Then, are you familiar with the way of how to assign to your mouse in general? Have you done it before?
Your previous thread is THIS
