HI
I Have code that change object layer
My problem is ... I want keep the last object selected (text, line, block...) and be able to add new object (select on screen)
My initial code was
Dim sset As AcadSelectionSet Dim acEnt As AcadEntity Dim objlayer As AcadLayer On Error Resume Next ThisDrawing.SelectionSets.Item("SS1").Delete Set sset = ThisDrawing.SelectionSets.Add("SS1") sset.SelectOnScreen ....
I'm going to remove the . Delete
I try with sset.Select acSelectionSetLast, but it's not working.
Is anyone know the solution?
Try similar code, not finished to your needs, just a quick demo
Change entity names In the filter
Option Explicit '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~' ' NOTE: ' Go to Tools--> Options --> General tab --> Error Traping --> check "Break on Unhandled Errors" '~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~' Public Sub TextSelection() Dim ent As AcadEntity Dim objSSet As AcadSelectionSet Dim setObj As AcadSelectionSet Dim oText As AcadText Dim oMText As AcadMText Dim intFilterType(0 To 0) As Integer Dim varFilterData(0 To 0) As Variant Dim dxfCode, dxfValue intFilterType(0) = 0: varFilterData(0) = "TEXT,MTEXT,INSERT,LINE,CIRCLE,LWPOLYLINE" ' Creates an empty selection set. Dim setColl As AcadSelectionSets With ThisDrawing Set setColl = .SelectionSets For Each setObj In setColl If setObj.Name = "mySelSet" Then .SelectionSets.item("mySelSet").Delete Exit For End If Next Set objSSet = .SelectionSets.Add("mySelSet") End With objSSet.SelectOnScreen intFilterType, varFilterData If objSSet.Count = 0 Then Exit Sub End If Dim before As Integer before = objSSet.Count MsgBox "Selected objects: " & before & vbCr & _ "Select single objects, hit Enter to stop " Dim Util As AcadUtility Set Util = ThisDrawing.Utility Dim pickPt As Variant Dim oEnt As AcadEntity On Error Resume Next Do Util.GetEntity oEnt, pickPt, vbCr & "Select object: " If Err.Number <> 0 Then Debug.Print Err.Description Exit Do Else ReDim addObjs(0 To 0) As AcadEntity Set addObjs(0) = oEnt ' Add the array of object to the selection set objSSet.AddItems addObjs End If Loop objSSet.Update MsgBox "Added objects: " & CStr(objSSet.Count - before) & vbCr & _ "All selected: " & CStr(objSSet.Count) End Sub
Thanks Hallex for your help.
