Any problem getting the resource via Explorer ?
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message news:6328834@discussion.autodesk.com...
Has anyone run across the following error when making an HTTP request?
"the download of the specified resource has failed"
The following code snippet produces the error.
Dim HttpReq As Object
Set HttpReq = CreateObject("MSXML2.XMLHTTP")
HttpReq.Open "POST", "http://127.0.0.1:8080/AppTest/SearchServlet", False
HttpReq.Send 'The error occurs here. "the download of the specified resource
has failed"
It doesn't matter if I use synchronous or asynchronous. Or if I use
MSXML2.XMLHTTP or Microsoft.XMLHTTP.
The kicker is that this code worked previously when I was using a trial version
of AutoCAD, but is now not working after I installed the licensed version. I
don't see any connection, but that was the only thing that changed. I'm using
AutoCAD 2010 on a Vista PC.
