Delete all objects on a layer in VBA
HI All,
I've seen the example code in the Developer help.
The example is as follows:
for each obj in ThisDrawing.Groups
obj.Delete
next obj
How can I apply this to all objects on a layer AND how should I declare obj
DIm obj as ??
if obj.layer = "your layer name" then
obj.delete
you can use AcadObject or AcadEntity - not sure which is best
"Mike Rand" wrote in message
news:[email protected]...
> HI All,
> obj.Delete
> next obj
obj
> DIm obj as ??
Mike,
Here is how you would do that.
Joe
Public Const LAYER = 8 'by layer
Public Function CreateSelectionSet(SelectionSet As AcadSelectionSet, _
FilterCode As Integer, _
FilterValue As String) As Boolean
Dim iFilterCode(0) As Integer
Dim vFilterValue(0) As Variant
iFilterCode(0) = FilterCode
vFilterValue(0) = FilterValue
SelectionSet.Select acSelectionSetAll, , , iFilterCode, vFilterValue
'SelectionSet.SelectOnScreen intFilterCode, varFilterValue
If SelectionSet.Count Then
CreateSelectionSet = True
End Function
Public Sub DeleteEntitiesOnLayer(LayerName As String)
Dim objSS As AcadSelectionSet
Dim oEntity As AcadEntity
On Error Resume Next
'delete any previous selection set
ThisDrawing.SelectionSets("Entities").Delete
'create our new selection set
Set objSS = ThisDrawing.SelectionSets.Add("Entities")
'get the actual entities for the selection set
CreateSelectionSet objSS, LAYER, LayerName
'iterate through selection set delete each entity
For Each oEntity In objSS
oEntity.Delete
Next oEntity
End Sub
Public Sub Test()
DeleteEntitiesOnLayer "... Your Layer Name Goes Here ..."
End Sub
Hey Joe
Why you have taken this:
what is 8??
Sachin
Sachin,
This might get you going
Public Sub eraselayer()
Dim ent As AcadEntity
For Each ent In ThisDrawing.ModelSpace
If ent.Layer = "1ST-PBASE" Then ' put layer name to delete here...
ent.Delete
Next
End Sub
john coon
wrote in message news:[email protected]...
Hey Joe
what is 8??
Sachin
Why not use a selectionset and then call the erase method on it?
"John Coon" wrote in message
Sachin,
ent.Delete
Next
End Sub
john coon
Hey Joe
what is 8??
Sachin
Ent works fast & easy. if I'm writing sometime where I'm going to access a
huge drawing I'll use a selectionset or if it's a routine I plan to add to
my companies routines I would add the selectionset but if it's sometime fast
down and dirty I'll use ent
John Coon
" Nemorarius" wrote in message news:[email protected]...
Sachin,
ent.Delete
Next
End Sub
john coon
Hey Joe
what is 8??
Sachin
