Createobject problem to AcadM 2011
Message 1 of 13
I've a program written in VB6 which starts Autocad:
Public oAcadApp As AcadApplication
Set oAcadApp = CreateObject("AutoCAD.Application.18.1")
on a PC with XP 32 bit there is no problem but on a PC with XP 64 bit -> oAcadApp stays Nothing, while Autocad does start up properly.
Do I miss something? Is there a difference between 32 bit and 64 bit for VB6?
Geert
Replies (12)
Message 2 of 13
I've got a similar problem...
I'm using 'AutoCAD_Instance = CreateObject("AutoCAD.Application")' to open AutoCAD... I'm not including the version because my company upgrades every year and I don't want to have to re-issue the app each time...
On WinXP, one user has both 2011 and 2010 installed... it works perfectly, opening the last version opened (same as double-clicking on a dwg file in Windows)... but in Vista, I get the error you mentioned...
Any thoughts?
Message 3 of 13
hi, my solution was to declare:
Public oAcadApp As Object -> instead of AcadApplication
Good luck,
Kind regards,
Geert
Message 4 of 13
Yeah, I've got that done - works fine with XP (and apparently Windows 7) but not Vista...
Message 5 of 13
We only use XP - 32 bit and Win7 - 64 bit so with Vista I can't help you.
On Win7 - 64 bit it works with Object, but it's a workaround at the problem and isn't a nice solution.
But it works for me.
Geert
Message 6 of 13
I change it too and still doesn't work. I on Windows 8.1 64 bit, VB 2013 tryng to run an instance of Autocad 2014 64 bit.
The Acad.exe runs on task manager but after a little it stops and the next line of code gets an exeption
'doesn't work
Public AcadApp As Object
AcadApp = CreateObject("AutoCAD.Application")
AcadApp.Visible = True
'doesn't work
Dim AcadApp As Object
'doesn't work
Dim AcadApp As AutoCAD.AcadApplication
Message 7 of 13
Alfred.NESWADBA
A few questions to make your issue more clear to us:
  • Where is the VBA code running? In an Excel or Word or ...VBA? 32bit or 64bit?
  • When you say "Acad.exe runs" ... was it running before you started your code or did it start when you started your code?
  • When you say "gets an exception" ... what exception do you get?
  • When you say "next line of code" ... what is the "next line" for you?
One syntax issue might exist: change your line with "CreateObject" according to that:
   Set AcadApp = CreateObject("AutoCAD.Application")
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 8 of 13
I'm sorry for posting everywhere, that's my first time on forums. The answers are:
1- the code is running in visual studio 12 (2013), I think its 32 bit because its installed on x86 program files
2-acad.exe is closed before and when i run my program it starts running acad.exe on task manager then after a moment it closes itself and then i got the exeption on visual studio
3-the next line of the code is "visible = true" or "acadapp.visible = true"
4-the exception is:
"An unhandled exception of type 'System.Runtime.InteropServices.COMException' occurred in BasicApp01.exe
Additional information: The server threw an exception. (Exception HRESULT: 0x80010105 (RPC_E_SERVERFAULT))"
5-I tryied adding "Set" before that line of code but visual studio delete it automatically and I can run Excel normally without it
my entire code is:
6-I already added the references for autocad too.
7-I have tried adding AutCad.Application.19 and it won't work either
I think i got an exeption because there is no acad.exe running to make visible, so the problem must be in the "CreateObject" line.
tank you.
Message 9 of 13
Alfred.NESWADBA
Ok, it's not VBA (as the initial poster mentioned in his first problem description). And yes, with VB.NET the "Set" is not necessary as I suggested previously.
No, the directory where Visual Studio is installed does not give you the info about the environment your developed/compiled EXE is running. If your EXE is running in 64bit- or 32bit-mode depends only on your project settings.
>> [...] so the problem must be in the "CreateObject" line
Set a breakpoint at the line with .Visible, start your exe, let your code wait at the break point and see (in the taskmanager) if the process ACAD.EXE stays alive as long as your code does not execute the codeline with .Visible. Execute your code then line-by-line, just to know if AutoCAD stops at the line with .Viisible or AutoCAD stops at the end of your sub (as the variable for the AcadApplication get's destroyed).
I have attached a sample (as simple as possible), that works for me and should work for you too.
- alfred -
Alfred NESWADBA
Message 10 of 13
Hi, Alfred
I did i little search at the program but i really don't know where I can see if the program is setted up as x86 or x64. I'm looking at google but so far I did not find out how to.
I did this and the acad.exe does not stay alive with the break point at .Visible
As I could not find line-by-line run option like in Office VBA Editor with the F8 key (I did not found it on google either how to, I guess it doesn' have this option) so I set up breakpoints and use F10 (Step Over) e F11 (Step Into) keys. It's not the same result to make a clear answer if it shuts before the End Sub or with it.
The program you sent me is pretty much what I want to do but it didn't work either. When I run it I got an error window saying: Error during initialization of AutoCAD: Failed remote procedure call (Exception of HRESULT: 0x800706BE and acad.exe also stops running. I did set breakpoints in your code too and the result was the same. Your program worked for you with the same enviroment configurations? (Windows 8.1 64bit, Autocad 2014 64bit)
Tanks for the help 🙂
Message 11 of 13
Alfred.NESWADBA
Within Visual Studio right-click the project ==> properties, goto tab "Compile" and there you find "Target CPU", that is where to set the mode to 32bit, 64bit or make it depending on the operating system.
>> As I could not find line-by-line run option [...]
You found <F10> and <F11>, so you found the option to run every single line separately 😉
I used my EXE with AutoCAD 2015, not 2014, but I don't think that this will make a difference.
BTW: have you ever started a repair installation of your AutoCAD?
- alfred -
Alfred NESWADBA
Message 12 of 13
Alfred, I found out what was the problem:
When I first installed AutoCAD I did some mods to improve performance and one of them was stoping AutoCAD from creating a Drawing1.dwg on startup. When I enabled it again everything worked out. Thank you very much for the help.
Natanael =D
Message 13 of 13
Alfred.NESWADBA
thank you for your feedback!
- alfred -
Alfred NESWADBA
