Wheel Clearance Envelope
I'm starting to look at vehicle tracking after being a user of aeroturn/autoturn. Is there a way to get a clearance envelope based on an offset from the main gear of an aircraft (vehicle)?
Thanks for the help
spsluka
Using the Vehicle Tracking reports you can add offset envelopes to a lot of things.  Each element can have up to two (2) offset envelopes added to it.  In the attached image I modified one of my reports to add a 5' offset envelope and a 10' offset envelope around the gears of the plane shown with cyan and green.  I also added a 25' body envelope shown in blue.  I used to be a AutoTurn user myself and have been extremely happy with all the results I have been able to get out of Vehicle Tracking.  Hope this helps you out!
Exactly what I was chasing. Thank you!
