Vehicle Tracking Forum
Welcome to Autodesk’s Vehicle Tracking Forums. Share your knowledge, ask questions, and explore popular Vehicle Tracking topics.
Vehicle Tracking Setup
3 REPLIES 3
cwdeep
1561 Views, 3 Replies
I'm having problems getting vehicle tracking to show up in the menu.  I've loaded it per the instructions "appload" and select the file and it says that it loads successfully, but I don't see it on my menu bar when I'm in CAD.  I'm sure that I'm doing some kind of simply bonehead thing (or not doing something simple), but I've read up on this and can't seem to get it to work and I know I've used it before in a previous version without any issue.  Any help would be greatly appreciated!!!!
3 REPLIES 3
jpiaskowy
in reply to: cwdeep
Try to load the .cuix file for the vehicle tracking software.
  1. Use command "CUILOAD" (you can also go through the "User Interface" menu)
  2. Browse to the vehicle tracking partial customization file (cuix). Mine is found here: "C:\Users\<USERNAME>\AppData\Roaming\Autodesk\Vehicle Tracking\Menus\atrc201.cuix"
  3. Click Ok then Load
  4. You might have to close and open Autocad for changes to apply
Hope this works for you.
nigel.peters
in reply to: cwdeep
cwdeep,
What version of AutoCAD are you running in atra200_arx.arx will only work on AutoCAD 2015?
From the screen grab, it looks like your are running in AutoCAD 2016 and the message at the bottom of your screen grab is tatting that it "failed to load atra_200_arx.arx" where are you seeing the successfully loaded message?
You need AVT 2016 for use in AutoCAD 2016
Nigel Peters
Nigel Peters
Vehicle Tracking Product Owner
Software Development Manager
cwdeep
in reply to: cwdeep
2016, but I had 2015 installed before and I think that's my issue. Thanks!
Charles W. Deep, PE, LEED AP BD+C
President
603 S. Lake Drive
Lexington, SC 29072
(O) 803-356-0909
(C) 803-917-2903
Charlie@4DEngr.com
