I'm having problems getting vehicle tracking to show up in the menu. I've loaded it per the instructions "appload" and select the file and it says that it loads successfully, but I don't see it on my menu bar when I'm in CAD. I'm sure that I'm doing some kind of simply bonehead thing (or not doing something simple), but I've read up on this and can't seem to get it to work and I know I've used it before in a previous version without any issue. Any help would be greatly appreciated!!!!
Solved by nigel.peters. Go to Solution.
Try to load the .cuix file for the vehicle tracking software.
Hope this works for you.
cwdeep,
What version of AutoCAD are you running in atra200_arx.arx will only work on AutoCAD 2015?
From the screen grab, it looks like your are running in AutoCAD 2016 and the message at the bottom of your screen grab is tatting that it "failed to load atra_200_arx.arx" where are you seeing the successfully loaded message?
You need AVT 2016 for use in AutoCAD 2016
Nigel Peters
