I've been working on this for two days now, and I'm becoming rather frustrated. Every time I add a new trailer and try to edit the couplings it crashes. In some cases the diagram in the wizard doesn't actually match the dimension I'm editing.
Worst of all I have to erase everything from the drawing, make an edit, then create another path to see the result of each edit.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve,
Is there anyway that you can create a screencast of how you are editing vehicles. I have just done a few quick tests and cannot get the editor to crash.
Nigel Peters
Reference CER 144569220 and 144569260
Edit a copy of an existing vehicle. Add a trailer and then attempt to edit the coupling of that new unit. Crashes every time.
Steve
Steve,
I can reproduce the crash on our end and have logged a product defect with the steps. In the mean time there is a simple work around, instead of adding the unit in the explorer view, select the vehicle and use the advanced editor to add and edit the unit.
Nigel Peters
Hi All,
I am creating a custom Super Quad Vehicle in the app and am also having a crash issue when I try and add my last trailer. I have successfully add 7 units, but every time I add my 8th unit it crashes as soon as I try to close and save. Is there a limit to the amount of units you can add to one vehicle?
Does Nigel's work around of using the Advanced Editing tools make any difference?
I see that you are using a combination of hitch types. What happens if you make them all drawbars?
Edit: This did end up working ! Striaght to the edit with advanced editor. Thank you
