Vehicle Tracking Forum
Welcome to Autodesk’s Vehicle Tracking Forums. Share your knowledge, ask questions, and explore popular Vehicle Tracking topics.
To make default a custom parking standard?
5 REPLIES 5
lesleyannmintoff54FXU
487 Views, 5 Replies
Why the software doesn't allow you to make default a custom parking standard?
5 REPLIES 5
Does the "Set as Default Parking Standard" not work?
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Try taking a look at this.
https://help.autodesk.com/view/VEHTRK/ENU/?guid=GUID-C57AFFCB-1FEB-48AD-95A3-70ECBF82D279&v=2023
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Fast Track your site grading with the new Corridor Workflow: https://youtu.be/Gg7u9-LgIL0
To make a custom parking standard the default, you usually need to go to the settings or preferences of your operating system or software. Look for options related to units of measurement or distance, select your custom standard, and set it as the default. The specific steps may vary depending on what you're using.
It seems like the software might not support setting a custom parking standard as the default due to its limitations or predefined settings. It could be worth checking for any software updates or configuration options that might allow this feature. If not, contacting support could help clarify if this functionality can be added or is planned for future updates.
following further
