Looking to see if there is a way to re arrange report order in Vehicle Tracking. In attached image, looking to simply move the bottom report in between where the red arrow points. Seems that reports that are positioned on top are sent to the back of the movement and reports on the bottom are sent to the front. This way I can create a truck with a fill and the fill doesn't over wright the truck outline. Any help is much appreciated.
Steve
Solved by spsluka. Go to Solution.
I figured this one out myself. Simply duplicating the reports again in the order I wanted and then deleting the old reports did the trick.
