Hello:
I just want to know how can i transform the legs alignements in a roundabout design into lines and circuls and not into little lines as do vehicle tracking, because alignaments are made with lines amb circuls with not decimals radius.
Thank you. (excuseme for me english)
Victor
Hi Victor
On the corridor tab select create/maintain alignments for the roundabout leg.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
No, i can't ajust the legs of the roundabout like and alignement.
I show you a picture with the problem, and also send you the dwg file of the exemple.
Thank you
Vic
Hi Vic
Thanks for the clarifications. From the look of the drawing, you are in Civil3D, in which case you have the option to create/maintain alignments via the Civil3D corridor tab in the Junction properties but this does not enable you to create the alignments you want.
It would seem that you have new requirements that:
Finally,
Could you please confirm that we have understood your requirements.
More or less yes. As you said it is not possible design geometry "as i like" in Vehicle tracking.
I has want like the attachet file.
Please, view it and give me you opinion.
Thank you
victor
Hi Victor
The latest build of Autodesk® Vehicle Tracking is 2015.3 and it has provided the following enhancements regarding roundabouts. Are you using build 2015.3?
http://docs.autodesk.com/AVT/2015/ENU/readme_2015.3/readme_vehicle_tracking.html
Roundabout elevations
An issue that impacted Autodesk® Vehicle Tracking roundabouts in Autodesk® AutoCAD® Civil 3D® has been resolved. This issue caused the centerline elevations of the approach and exit halves of each arm of the roundabout to differ.
Affected roundabouts in existing drawings can be updated by performing the following task:
Note: If the profiles and corridor are not updated automatically when you perform step 4, run the _adskJunctionEdit command, click 3D Corridor to display the Corridor properties, select the Update Profiles and Update Corridor check boxes, and click Rebuild Now.
5. Repeat steps 3 and 4 for each roundabout in the drawing.
Hi Victor
The AVT development team acknowledge that they are aware of your requirement and have informed me that they are investigating the rules that need to be implemented to enable the rounding of the relevant parameters.
Thank you for your patience and help in helping to identify and define this issue.
Viji
IF you are using AVT in Civil3D you do get a "linked/Managed" polyline under the outside curb and can switch on linked alignments for a lot of the geometry.
Could you send me a list of lines you would like exposed. We are al;so aware of the request to change the curbs from conpound curves to a "fixed" rounded radii curves to make laying out easier. Please let me know if you have exact requirements in this area.
Nigel
Hi Nigel.
Just see the drawing of the post nº 6. Where you can see the geometri more or less that we ned.
Thank you
Vic
Has there been any more progress on this issue? This software works great, however the line work that is developed is not usable in real life applications.In order for this to be used, the line work needs to be tangent, polylines and curves and not multiple polyline segments.
Long time.
Has there been any more progress on this issue in the new version 2018?
From Vehicle Tracking 2017, new setting Arm Base Alignment Curve Type is added on Roundabout Properties and Standard Editor dialog, and support Arc and Spline curve.
I think Arc arm base alignment can meet your requirement, right? - If users set Arc for curve type, single arc shows for the alignment.
Hope it helps.
Thanks.
Thanks for all the answers, but the problem persists.
Just design of a roundabout between two alignments (not straight alignments but circles or spirals) and the problem persists.
We will have to design roundabouts with the manual method, alignments to alignments.
First of all Autodesk should solve the design in 2d of the roundabout with all the alignments, and later realize the design in 3d like do now Vhecle Tracking..
