Vehicle Tracking Forum
Welcome to Autodesk’s Vehicle Tracking Forums. Share your knowledge, ask questions, and explore popular Vehicle Tracking topics.
How to add landing gear for the trucks
3 REPLIES 3
SKishoreU686B
271 Views, 3 Replies
Hi .... In Vehicle tracking trucks there is no Landing gears added. I added manually as block in in Vehicle tracking but its looks that block some were located. it's not coming properly. how i did explained in my attachment. Can anyone help me to how to add Landing gears in Vehicle tracking trucks...
3 REPLIES 3
hanery435
in reply to: SKishoreU686B
To add landing gear to your truck, you'll need to choose the right type, prepare your truck, install mounting brackets, attach the landing gear, and test its functionality. Make sure to consider weight capacity, safety, and professional installation if needed.
SKishoreU686B
in reply to: hanery435
Thanks for your reply .. Actually, i am looking for how to add landing gear in Civil 3D Vehicle library Trucks ...
tamseel8345
add landing gear for trucks in vehicle tracking, make sure the block you added is placed correctly within the vehicle's model or configuration. Check if the block's position needs adjustments or if you need to use a specific module or feature for landing gear. Ensure that you're following the software's guidelines for adding custom elements. If issues persist, consult the platform's support or community for detailed instructions on properly integrating landing gears in your tracking system.
