Vehicle Tracking Forum
Welcome to Autodesk’s Vehicle Tracking Forums. Share your knowledge, ask questions, and explore popular Vehicle Tracking topics.
Can i make vechicles follow a path?
3 REPLIES 3
2529 Views, 3 Replies
Is it possible to make my vehicles autodrive along a centerline? Or do i have to manually click along the route i want it to follow?
For instance can i offset the centerline and make the vehicle autofollow?
3 REPLIES 3
Joe-Bouza
Not only can you but I strongly recommend that you do.
Draw the path with a civil3d alignment using the minimum radius (maybe slightly larger) of the vehicle. Select the vehichle right click and pick follow>> then select the alignment.
I like this for three reasons:
1. the finished movement will be smooth without all the markers created by the mouse clicks
2. modifying the path for corrections is much easier by grip editing the alignment ( the minimum radius will be maintained
3. using the alignment tools it easier IMHO to create scenarios.
Joe Bouza
in reply to: Joe-Bouza
Thank you for the answer, I will definately do this in the future
hanery435
Absolutely! You can create vehicle paths and have them follow them in various game development environments.
Here are some common methods:
1. Waypoints:
  • Define a series of points (waypoints) along the desired path.
  • Vehicles can follow these points one by one, using techniques like steering behaviors or pathfinding algorithms.
2. Pathfinding:
  • Use pathfinding algorithms like A* or Dijkstra's to calculate the optimal path between two points, considering obstacles and terrain.
  • Vehicles can then follow this calculated path.
3. Spline-Based Paths:
  • Create a smooth curve (spline) that defines the path.
  • Vehicles can follow this curve using mathematical techniques like Bezier curves or Catmull-Rom splines.
4. Procedural Generation:
  • Generate paths procedurally based on terrain or other factors.
  • This can create more dynamic and varied paths.
5. User-Defined Paths:
  • Allow players to draw or define their own paths.
  • This can provide more customization and replayability.
