C3D as AutoCAD - English No Longer Starts Right after Installing Vehicle Trackin
C3D 2018.2
Vehicle Tracking 2018.2
I run C3D and Vehcile Tracking is part of the license package so I installed it. Now AutoCAD is broken. the shortcut target for AutoCAD is: "C:\Program Files\Autodesk\AutoCAD 2018\acad.exe"  /product ACAD /language "en-US"
At first on start it didn't load acad.cuix right, so I restored it through CUI. I had the CMDDIA set itself to 0. Layer manager doesn't work right. I get a "Unable to find main dictionary. Could not start speller." error when I run CUI, but then CUI works after OK'ing the error away. When I try to start the layer manager I get command line options, but no layer dialog. In the CUI the main customization file is VEHICLE TRACKING - which led me here and why I think it is the culprit. it thinks its C3D I think? See below from when it starts.
What do I need to do to restore vanilla AutoCAD operation?
thanks.
Customization file loaded successfully. Customization Group: VEHICLETRACKING
Customization file loaded successfully. Customization Group: APPMANAGER
Customization file loaded successfully. Customization Group: FEATUREDAPPS
Customization file loaded successfully. Customization Group: BIM360
Customization file loaded successfully. Customization Group: EXPRESS
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: AUTODESKSEEK
Loading AEC Base...
Loading AECC Base...
Loading Modeler DLLs.
Loading AEC Base Extended...
Loading AEC Core...
Loading AECC Land...
Loading AECC Subentity Selection...
Loading AEC Project Base...
Loading AEC Architectural Base...
Loading AECC Pipe Part...
Loading AECC QTO......
Loading AECC Pipe Network...
Loading AECC Pressure Pipes...
Loading AECC Roadway...
Loading AECC Hydrology...
Loading AECC Survey...
Loading AECC Plan Production...
Loading AECC Building Site...
Loading AECC Point Cloud...
Loading AecCivilBase...
Loading AEC Schedule...
Regenerating model.
Unable to access Shared Pipe Catalog folder.
Please verify configuration.
Run 'setNetworkCatalog' to reset.
; error: LOAD failed: "acad2018"
Type VEHICLETRACKING to load the Vehicle Tracking menus
Unable to find C:\Users\wudar\AppData\Roaming\Autodesk\C3D 2018\enu\Support\River.cuix.
River customization file is not loaded
_aeccShowVehicleTrackingRibbon
SECURELOAD 0 *Cancel*
Command: *Cancel*
FileTab
COMMANDLINE
nigel_peters
Not sure what is happening here, one thing to try is to tell Vehicle Tracking not to attempt to edit the ribbon at startup.
This can be done with the VEHICLETRACKINGSYSTEMSETTINGS command
Uncheck the Force menu to be visible option, close, and exit Autocad. It will not fix the issue but will remove Vehicle Tracking from your investigation.
Nigel Peters
Vehicle Tracking Product Owner
Software Development Manager
thanks! I will give it a try.
