ZoomAll from a VBA Excel program
oransen
oransen
I have inherited a piece of VBA which runs inside Excel and to which I have to add Zoom All. Here is the code, but the Zoom All part doesn't.
Sub AutocadSaveDWG()
On Error GoTo ASDWG_Err:
    Dim Application As AcadApplication
    Dim Document As AcadDocument
    Dim filepath As String, sDate As String, sTime As String
    Dim saveFolder, Filename As String
    Set Application = GetObject(, "AutoCAD.Application")
    Set Document = Application.ActiveDocument
    saveFolder = "C:\DisegniSviluppati\"
    sDate = GetFileNameString(Date)
    sTime = GetFileNameString(Time)
    ' This filename takes the type of machine and adds the date
    Filename = Worksheets("DEVES_TABLE").Range("D10") & "_" & sDate & "_(" & sTime & ")"
    filepath = saveFolder & Filename
    ' Application.ZoomExtents
    Application.ZoomAll
    Document.SaveAs filepath
    Exit Sub
ASDWG_Err:
    ShowErrorMsgBox ("AutocadSaveDWG")
End Sub
Neither ZoomAll nor ZoomExtents works. What have I missed?
grobnik
Hi @oransen could you try with
Application.Document.ZoomAll
oransen
Ok, sussed, I need to use Visible = true, like this:
    Application.Visible = True
oransen
Thanks, I'll test that solution as well.
