VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Why do I get an exception "not open for write" when I try to read a AcadRotatedDim Measurement
4 REPLIES 4
oransen
192 Views, 4 Replies
Sometimes when I try to read a rotated dimension property I get an exception.
Surely calling Dim.Measurement does not change the entity?
Here is the code fragment:
        else if (entity.EntityType == Support.ikRotatedDimEnt)
            AcadDimRotated Dim = null;
            try
                Dim = (AcadDimRotated)entity;
                double x = Dim.Measurement; // <--- cause exception
            catch
                ABSup.Log.WriteLn(CLog.Type_e.ekLog, "Skipping a rotated DIM" );
Labels (2)
4 REPLIES 4
daniel_cadext
in reply to: oransen
I tried these with Python, no issues
import traceback
from pyrx_impx import Rx, Ge, Gi, Db, Ap, Ed, Ax
def PyRxCmd_xdoit1() -> None:
    try:
        dims = []
        ax_app = Ax.getApp()
        for ent in ax_app.ActiveDocument.ModelSpace:
            if ent.ObjectName == 'AcDbRotatedDimension':
                dim = Ax.AcadDimRotated(ent)
                dims.append(dim.Measurement)
        print(dims)
    except Exception as err:
        traceback.print_exception(err)
def PyRxCmd_xdoit2() -> None:
    try:
        dims = []
        ikRotatedDimEnt = 15
            if ent.EntityType == ikRotatedDimEnt:
        print(dims)
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
oransen
in reply to: daniel_cadext
Many thanks for your reply. Unfortunately it does not always happen, even in C#. Not sure if I'm allowed to share the drawing or not though. I'll get back to you.
daniel_cadext
It could be that those dimensions are associated with some entity, something is causing them to update
oransen
I'll have to investigate deeper I think...
AutoCAD Inside the Factory
