Here's the code...
private void Test1()
AcadApplication acadApp; // get a running instance of AutoCAD, or start one:
try
acadApp = (AcadApplication) Marshal.GetActiveObject("AutoCAD.Application");
catch ( Exception e )
acadApp = new AcadApplication();
string sVer = acadApp.Version; // This gives me sVer = "23.1s (LMS Tech)"
AxDbDocument dbxDoc = (AxDbDocument) acadApp.GetInterfaceObject("AxDbDocument.23.1s");
dbxDoc.Open(@"D:\Temp\CSHARP.DWG", string.Empty);
...GetInterfaceObject fails, with or without the last "s". Here's the error:
Name Value Type
| -2147221005 | int | ||
| Message | "Problem in loading application" | string |
See also the attached image (image insertion in the post does not work).
TIA
