VBA Project Read Only
norman_duke
norman_duke
Every time I make a change to my code and want make a save it keeps informing me that it is read only.
I have tried it on another PC and the same problem.
I have also created a new dvb using a Hello  World message box and get the same problem.
The files are located in the trusted Location.
Any ideas?
  • VBA
stephen_mitchell
What folder is the DVB saved in? Probably a windows security issue on that folder? Try moving dvb to a directory in documents folder and added this to your Trusted Locations.
norman_duke
Thanks for your reply.
I have found the problem. I had the folder that it was in linked to my One Drive Account.
Moved to a new folder which is not linked and problem appears to be solved.
Norman
