Use sendcommand in VBA to run the -PUBLISH command with the DSD-file
cve60069
Message 1 of 10
cve60069
I want to publish two layouts using VBA and I have had some success with the following code
ThisDrawing.SendCommand "-PUBLISH" & vbCr.
which I filched from another forum question: i.e. ".. you can use sendcommand in VBA to run the -PUBLISH command with the DSD-file as a parameter..."
When I run the VBA, I am prompted for the dsd file which is "NAGspecification.dsd" which has two layouts "Template 1 and Template 2" which I want to publish into a multiple sheets set.
How do I pass the parameters please?
Replies (9)
Message 2 of 10
cve60069
Set up the Publish Printer in Print>Batch Plot>Publish Options>Multi Sheet File
Add ThisDrawing.SendCommand "-PUBLISH" "NAGspecification.dsd" & vbCr to the code.
And it works.
Not sure if I am able to answer my own question but it is solved.
Message 3 of 10
cve60069
My last solution did not work. Not sure why it did but the correct solution is below.
ThisDrawing.SetVariable "FILEDIA", 0 'Stop dialog boxes
ThisDrawing.SendCommand "(command " & Chr(34) & _
"-PUBLISH" & Chr(34) & _
" " & Chr(34) & "NAGspecification" & _
Chr(34) & ")" & vbCr
ThisDrawing.SetVariable "FILEDIA", 1 'Reset dialog boxes
Author for this was  Mike Tuersley
Message 4 of 10
Can you please share that .dsd file?
Message 5 of 10
cve60069
You need to create a DSD file yourself. How to create the DSD file and edit. 1. create the layouts that need to be published. To do this 2. select the layouts and right-click and publish. 3. you will be asked to save the layout set to a DSD file. Say yes and save. 4. The DSD file is a text file. Locate the DSD file on the hard-drive. 5. Using VBA, open the DSD file and read its contents into an array. 6. Manipulate the text as you want. I changed the names of the layouts to be published. 7. Save the DSD file onto itself. 8. Publish the layouts.
Message 6 of 10
I have my DSD file stored at "C:\Users\Documents\AutoCAD Sheet Sets\PublishData.dsd" this location. I just need help to write the VBA code to run this DSD file by giving "Publish" command.
Message 7 of 10
cve60069
ThisDrawing.SendCommand "(command " & Chr(34) & "-PUBLISH" & Chr(34) & " " & Chr(34) & "YourFilename" & Chr(34) & ")" & vbCr
' Pause for PDF publish
For i = 1 To 50
DoEvents ' Yield to other processes.
Next
Message 8 of 10
Thank for this, but this is not working. Not pdf file is getting generated.
Message 9 of 10
The above given code is just opening the dialog box but not selecting the DSD file (provided in code) automatically. It get stuck at the dialog box only. Please give the solution for this
Message 10 of 10
cve60069
eshwarmhase5
I am not an expert but I will try to help.  I have written a code that allows me to dynamically publish pdf's from a table and it works so I might be able to assist.
Are you able to show me your code.
