supressing auto regeneration via vba
I have written a vba routine to create a series of points in a drawing based
on information in a database. I would like to be able to regenerate at
certain points in the routine (when a layer is complete, for example). My
problem is that the drawing automatically regenerates everytime a point is
added. Ultimately this routine will be drawing >1 000 000 points, at which
point the time loss from regeneration after every point is added will be too
high.
I have tried turning autoregeneration off at the acad command line before
running the routine, but this hasn't worked. Is there a way to control
drawing regeneration from the vba routine?
Thank you.
Ursula Dillon
Ursula,
Have you tried ThisDrawing.SetVariable "regenmode", 0 ?
Gary
Thanks. That does work for turning the regeneration off, although it didn't
go to the source of my troubles. For some reason I decided that defining
the point style inside the loop was a good idea. Oops! Took that out and now
everything is running smoothly.
Ursula
> Ursula,
> Gary
before
