SQLite connection from VBA
mucip
mucip
I installed both 32 and 64 bir SQLite ODBC driver from here. I used this code in VBA but "Out of Memory" error appear.
When I use 32 bit DSN then "wron architecture" message appear. My machine is 64 bit.
Dim conn As Object, rst As Object
    Dim strSQL As String
   Set conn = CreateObject("ADODB.Connection")
   Set rst = CreateObject("ADODB.Recordset")
  ' OPEN CONNECTION
   conn.Open "Dsn=SQLiteDatasource64;Database=c:\Kurdak.db;Version=3;"
  strSQL = "SELECT * FROM test "
  ' OPEN RECORDSET
   rst.Open strSQL, conn
   ' OUTPUT TO WORKSHEET
   Debug.Print rst
   rst.Close
  ' FREE RESOURCES
 Set rst = Nothing: Set conn = Nothing
Where am I wrong?
I wish we have "table and search in table utilities" in VBA. 😞
Mucip:)
mucip
Hi again,
I found solution to my own question and wants to share here.
I used X64 ODBC Driver
  ' OPEN CONNECTION
   conn.Open "DRIVER=SQLite3 ODBC Driver;Database=c:\Kurdak.db;Version=3;"
  strSQL = "SELECT * FROM tartim "
  ' OPEN RECORDSET
   Do Until rst.EOF
    Debug.Print rst.Fields(1)
    Debug.Print "----"
    rst.MoveNext
    Loop
   rst.Close
  ' FREE RESOURCES
Mucip:)
mucip
And also SQLite memory table connection string here:
conn.Open "DRIVER=SQLite3 ODBC Driver;Database=:memory:;Version=3;New=True;"
Mucip:)
