Sendcommand
Sendcommand
Sendcommand
I got the following error message while using SENDCOMMAND to change the UCS in the program.
SOURCE CODE :
Dim objline As AcadLine
dim x as variant
ThisDrawing.Utility.GetEntity objline, x, "Select the cs line"
ThisDrawing.SendCommand "ucs" & vbCr & "n" & vbCr & "OB" & vbCr & objline.ObjectID & vbCr
ERROR MESSAGE:
Command: Select the cs line 'HERE I SELECTED THE LINE.
Command: ucs
Current ucs name: *WORLD*
Enter an option [New/Move/orthoGraphic/Prev/Restore/Save/Del/Apply/?/World]
: n
Specify origin of new UCS or [ZAxis/3point/OBject/Face/View/X/Y/Z] <0,0,0>: OB
Select object to align UCS: 25595312
No object found
When i tried the same in Command prompt, it is working fine.
Any help in this regard will be very useful.
Regards
Anand singh
    I had similar probems with the
sendcommand using earlier versions of
    A2000. Try updating to a
later build (T.1.07 seems to be o.k).
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
in the program.
SOURCE CODE :
dim x as variant
ERROR MESSAGE:
Command: ucs
Enter an option
<World>:
n
<0,0,0>: OB
No object found
Regards
Anand singh
Instead of using the sendcommand to change a ucs
you could maybe use this:
   Dim ucsObj As AcadUCS
Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(pdblOrigin, pdblPointX,
pdblPointY, "New_UCS")
   ThisDrawing.ActiveUCS =
ucsObj
I've been using that for awhile and it always seems
to work correctly, hope this might help 🙂
Michael.
in the program.
SOURCE CODE :
dim x as variant
ERROR MESSAGE:
Command: ucs
Enter an option
<World>:
n
<0,0,0>: OB
No object found
Regards
Anand singh
Ok I know there is the thisdrawing.SENDCOMMAND "_pline" IN ACAD 2000
But how can I get the Same thing in R14? I need to run a command line
command. Completion of my APP??
Please!!
You have to use the evallispexpr function from AcadUnsupp.arx (this contains
a couple of missing functions in R14 VBA)
Search for Acadunsupp.arx in the customer-files Newsgroup to find the file.
Luc Morrissette,
Flairbase inc.
"boswell" wrote in message
news:D732585EED5B532D2054AD727349D58E@in.WebX.maYIadrTaRb...
> Please!!
