Select Block based on Block Handle ID
conveyor1
Message 1 of 10
conveyor1
Does anyone know of a way to select a block in an AutoCAD drawing by it's unique block handle?  I am currently working on a program where it takes the block data out of the DWG and put it into excel for additional manipulation.  I would then like it to be sent back into the dwg with the update attribute information and dynamic block information.  i have most of this working, but it is slow.
The current code for putting the data back is a series of "for next" or "if then" statements to select the all autocad entities in the dwg, see if they are a dynamic block, see if it is the specific dynamic block I need to update and then update as required.  But when I have a hundred lines to update and more then a couple of hundred acadenities in the drawing, the looping takes time.
Do you know of a way to select only that block right off the bat?  I also will have the Block Name and it's insertion point.  I can also get any additional information from the block if required when I import the block into excel.
Please let me know when you can.
Replies (9)
Message 2 of 10
norman.yuan
If you know the Handle value of the target entities, you can call AcadDocument.HandleToObject([handle]). Note, you'd want to have proper exception handling code, in case the entity that had the handle previously has been erased prior to your code runs. In your case, the code would look like:
Private Function UpdateBlockReference (handleValue As String) As Boolean
    Dim obj As AcadObject
    Dim blk As AcadBlockReference
    On Error Go BAD_HANDLE
    Set obj=ThisDrawing.HandleToObject(handleValue)
    If TypeOf obj Is AcadBlockReference Then
        Set blk=obj
        If UCase(blk.EffectiveName)="MY_TARGET_BLOCK" Then
            '' Update this block reference
    UpdateBlockReference = True
    Exit Function
BAD_HANDLE:
    '' MsgBox "Invalid handle found!"
    UpdateBlockReference = False
End Function
Norman Yuan
Drive CAD With Code
Message 3 of 10
conveyor1
Morning,
For some reason this part of the code is not working.
I get an error stating "object required".
I have following for code
Dim Block_Handle_ID_Tag As String
Dim sht As Object
Set sht = ActiveSheet
For Counter = RowNum To LastRow
Block_Handle_ID_Tag = sht.Cells(RowNum, 18).Value
Set obj = thisdrawing.HandleToObject(Block_Handle_ID_Tag)
Code stops at the Set statement.
Please let me know your thoughts.
Message 4 of 10
norman.yuan
You did not say, but I'd guess your code run in Excel's VBA, right?
If so, of course "ThisDrawing" is not valid in Excel VBA.
You need to replace it with the variable referring to an opened AcadDocument object.
For example, in your Excel VBA, you might have this kind of code to connect to AutoCAD and open a drawing:
Dim cadApp As AcadApplication
Dim dwg As AcadDocumen
Set cadApp=New AutoCAD.Application
Set dwg=cadApp.Documents.Open ("....file path/name...)
Then you can use "dwg" to replace "ThisDrawing" in my code sample.
Norman Yuan
Drive CAD With Code
Message 5 of 10
conveyor1
Thought it would be something like that. What if I already have cad and
the DWG open?
Message 6 of 10
norman.yuan
Firstly, it is hardly a good workflow to automate a complicated desktop app, such as AutoCAD from another application (Excel app in your case): user unnecessarily has to face 2 applications for a task.
Anyway, in your Excel VBA side, if you want to update a given drawing, the usual process is to first try to find a running AutoCAD session. If found, check if the target drawing is open in AutoCAD session or not. If found, do something with the drawing. If the drawing if not found open, open it in AutoCAD. If there is no AutoCAD session, start one and then open the drawing.
The VBA code should look like something as following:
Dim dwg As AcadDocument
Dim targetDwg As AcadDocument
On Error Resume Next
Set cadApp=GetObject(, "AutoCAD.Application")
if cadApp Is Nothing Then
    Set cadApp = CreateObject("AutoCAD.Application)
    If cadApp Is Nothing Then
        MsgBox "Cannot start AutoCAD!"
        Exit Sub[Function]
Else
    For Each dwg In cadApp.Documents
        If UCase(dwg.Name) = "C:\MYFOLDER\MYDWG.DWG" Then
            Set TargetDwg=dwg
            Exit For
    Next
If targetDwg Is Nothing Then
    Set targetDwg=cadApp.Documents.Open("C:\MYFOLDER\MYDWG.DWG")
'' Now you have the running AutoCAD session and the target drawing
Norman Yuan
Drive CAD With Code
Message 7 of 10
Is there a way to give the block instance a unique name in Autocad so that I can use that unique name to reference the block instance in vba?  I understand handle but I prefer not to use it since the handle # doesn't have meaning and I don't have control over it.
Message 8 of 10
norman.yuan
It would be better for you to provide more detailed context in which "unique name" means. But let me make assumption. Say, you have a block called "WorkStation", and you insert 3 block references of of this block into drawing. Naturally, all 3 block references have name "WorkStation" shown in the Properties window. But you want give each block reference its own name, like "WorkStation 1" or "WorkStation 2" or "WorkStation 3", or simply "#1", "#2", or "#3". This extra piece of data can be either visible in drawing as required, or not visible but accessible programmatically (by code) for business reason.
If that is the case, AutoCAD's way of using block has already provide this functionality since its beginning of near 40 years ago: using Attribute within block. Add an attribute to the block with whatever tag you like, such as "Unique Name", "Station Number", or even "Name", and give the attribute a different value in different block reference. It the attribute is not meant for being visible and only accessed/controlled by programming code (to enforce the uniqueness, for example), you can flag the attribute as "Invisible". Also, besides Attribute, you can also attach data with unique value to block reference (and any type of entity, for that matter) as XData or ExtensionDictionary through your code.
But I'd think, in most cases, attribute is what you are to use, simple, easy and basic for every CAD user.
Norman Yuan
Drive CAD With Code
Message 9 of 10
Hello Norman.
Your assumption of what I'm trying to do is correct.  I have a drawing with multiple block instances.  I'm trying to write vba code that finds a certain block instance to change its tag value.
If I name my block instances with attribute, what is an easy way to reference those block instances in vba?  From my current knowledge of autocad vba, I would need to loop through the drawing's objects until I find an object that has a name tag value tha I'm looking for.  Once found I would set that object to a acadblockrefernce object.
Basically I wonder if there is a vba statement similar to the statement below but uses attribute tag value instead handle value.
Thank you for your help.
Message 10 of 10
grobnik
Hi @Anonymous , @norman.yuan
once you create a block with attributes you can use the code below to find your block with a wanted attribute name.
If you want modify the block in local, adding missing attributes, you can right click on block object and apply edit block in place, add attributes, save and upgrade the other same blocks.
For Each Block In Thisdrawing.ModelSpace
    If TypeOf Block Is AcadBlockReference Then
        If Block.Name = "S3886" Then ' Insert here block name
            If Block.HasAttributes = True Then
                Set MyBlock = Block
                MyAtt = MyBlock.GetAttributes
                For A = LBound(MyAtt) To UBound(MyAtt)
                    If MyAtt(A).TagString = "NAME" Then ' Name of attribute
                        NEW_NAME = "NEW_NAME"
                        MyAtt(A).TextString = NEW_NAME
                Next
Next
Thisdrawing.Regen acAllViewports
End Sub
When you create a block with attributes inside a drawing or template,  later by VBA you will have an array coming from BlockObject.GetAttributes function.
Each attribute will have TextString and TagString properties, TAGSTRING it's the "NAME" of Attribute, and TextString it's the content, so you can check inside all BlockObject attributes value the Name, and change the value.
