Running a vb6.0 project from vba code
Is it possible to run an executable I made in vb6.0 right from my vba
code? If so, can anyone tell me how this is done? Thanks in advance.
Yes. If your app is an ActiveX server, use GetInterfaceObject. If not, use
Shell.
The Common Sense Copyright
You are free to do whatever you want with the information in this post.
I only ask two things:
1) If you reprint it, please credit me as the author.
2) If you make money with it, please cut me in.
http://www.acadx.com
"Monica" wrote in message
news:9122EFCAB50BE2B75E246D5B295E5FE4@in.WebX.SaUCah8kaAW...
Actually, the sole purpose of this short vba program is to allow the user,
while in autocad, to click on my toolbar icon and run a vb6.0 .exe. The
only way I know how to do this is through vba code. Is this thinking
correct?
"Frank Oquendo" wrote in message
news:2DD4370E09DC35FF516457815C3A964E@in.WebX.SaUCah8kaAW...
> Shell.
Hi Monica,
You can use startapp. In a toolbar button:
(startapp "mypath/myfile.exe")
-Josh
> correct?
> > Shell.
tried that suggestion, but I got this error ;
"unknown command STARTAPP"
"Minkwitz Design" wrote in message
news:3A196051.3858DA19@minkwitz-design.com...
> Hi Monica,
> -Josh
user,
> > correct?
use
> > > Shell.
post.
vba
advance.
Did you place it in the parenthesis so that it is recognized as lisp? In
addition, add a semicolon at the end for a return stroke. From the acad
help files on the topic:
You can use the acad.pgp file to define a new AutoCAD command that runs
an external command to start your application. The following example defines
the RUNAPP1 command, which runs the application app1.exe in the C:\vbapps\
directory. (Add this code to the external commands section of your acad.pgp
file.)
RUNAPP1, start c:\vbapps\app1, 0
If your application requires command line parameters, you can use the
following code:
RUNAPP2, start c:\vbapps\app2, 0, *Parameters: ,
The previous example defines the RUNAPP2 command, which prompts you
for parameters and then passes them to your application. For more information
on the acad.pgp file, see "acad.pgp—Program Parameters File."
You can also use the AutoLISP startapp function
to start an application that makes use of Automation. Once AutoLISP starts
the external application, it has no control over its actions. You can,
however, use AutoLISP to locate and run different applications based on
certain parameters.
Starts a Windows application
(startapp appcmd [file])
Arguments
appcmd
A string that specifies the application to execute. If appcmd does not
include a full path name, startapp searches the directories in the PATH
environment variable for the application.
file
A string that specifies the file name to be opened.
Return Values
An integer greater than 0, if successful, otherwise nil.
Examples
The following code starts the Windows Notepad and opens the acad.lsp
file.
Command: (startapp "notepad" "acad.lsp")
33
If an argument has embedded spaces, it must be surrounded by literal
double quotes. For example, to edit the file my  stuff.txt with Notepad,
use the following syntax:
Command: (startapp "notepad.exe" "\"my stuff.txt\"")
33
-Josh
"Minkwitz Design" <mds@minkwitz-design.com> wrote in message
> Hi Monica,
> -Josh
the
user,
The
thinking
> > correct?
> > "Frank Oquendo" <franko@nospam.stonemedia.com> wrote in message
If not,
use
> > > Shell.
this
post.
> > > "Monica" <meisfeld@supersky.com> wrote in message
right from my
vba
Thanks in
advance.
