Run .bat file from visual Basic command Button
Message 1 of 11
I have a .bat file set up and rather than search through explorer I want to be able to click a button on a userform to run the batch routine. Userform and button are also set up.
Replies (10)
Message 2 of 11
Hallex
Try this code
Option Explicit
Private Declare Function ShellExecute Lib "shell32.dll" Alias "ShellExecuteA" (ByVal hWnd As Long, ByVal lpszOp As String, ByVal lpszFile As String, ByVal lpszParams As String, ByVal lpszDir As String, ByVal FsShowCmd As Long) As Long
Public Function RunCMD(ByVal FileName As String) As String
   RunCMD = ShellExecute(0, "open", FileName, "", "", 1)
End Function
Private Sub CommandButton1_Click()
Dim fname As String
fname = "C:\\Temp\\test.bat"
RunCMD fname
DoEvents
MsgBox "| Done |"
End Sub
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 11
hallex,
I tried it out but it still doesn't work.
As i Run the routine, click on the command button the cmd window pops and then the msgbox "DONE" but it is still not running the .bat file
I changed the path to the path where my .BAT is saved.
I have also independently checked the .bat file which defiantly works.
Do you have any other suggestions?
CJS
Message 4 of 11
Hallex
Try this project
Tested on A2009 only
Change bat file name in the code
~'J'~
Message 5 of 11
Your coding works but i still can't get it to work on my bat routine,
However i think i have found the problem but can't find the solution,
i have tried it on 2 seperate routines.
  • 1 routine, the file path has no spaces - this works - gives me a TXT file listing all drawings named "CSKTransport.txt"
  • 1 routine, the file path has space - this doesn't work (the one i need)
I think the problem lies with the spaces. Here is my bat code:
@echo off
setlocal enabledelayedexpansion
title Drawing Lists
color 0a
cd "P:\027566\F08 - ITE\Sheet\CSK Transport\"
dir "P:\027566\F08 - ITE\Sheet\CSK Transport\"*.dwg /b /s>CSKTransport.txt
echo
pause
msg * List Created!
I am pretty sure the VBA part is correct as it is opening up this bat file (title "Drawing Lists" appears on DOS window)
any suggestions?
CJS
Message 6 of 11
Hallex
I used following bat file
@echo off
title Drawing Lists
color 0a
cd "C:\Test\New Folder\"
dir "C:\Test\New Folder\"*.dwg /b /s>CSKTransport.txt
echo
pause
msg * List Created!
working good on my machine
I don't know how to fix your problem, sorry
Try search Google about blank spaces in the file name
or rename your folders
~'J'~
Message 7 of 11
Hallex, Thanks for your advice. For some strange reason I tried it first thing this morning and it worked without me changing any of the code! CJS
Message 8 of 11
Hallex
I have the same things often Smiley Happy
Glad you solved it though
~'J'~
Message 9 of 11
GTVic
You should probably replace the .BAT code with VB for the best results:
Dim s as string, t as string, i as integer
t = "P:\027566\F08 - ITE\Sheet\CSK Transport\"
i = freefile()
open t + "CSKTransport.txt" for output access write as #i
s = Dir$(t + "*.dwg",vbArchive + vbHidden + vbNormal + vbReadOnly + vbSystem)
Do While s <> ""
    print #i, t + s
    s = Dir$
Loop
close #i
Message 10 of 11
https://www.youtube.com/watch?v=1GAYtDkCG4A
watch how to execute a batch file using visual basic 6.0
Message 11 of 11
watch tutorial on how to run a batch file (CMD) using VB6 command button
