Repeat function using Timer is getting stuck in a loop before repeating in VBA
ryan.yong00048L8LW
Message 1 of 1
ryan.yong00048L8LW
Using a previous solution on this forum as a reference: https://forums.autodesk.com/t5/vba/re-repeat-function-in-autocad-vba/m-p/10618756/highlight/false#M1... I am using a modification of this code to call an external function every 5 seconds.
It runs normally for the most part, but for reasons unknown to me, the code can get stuck looping between the 3 lines :
"Do While Timer < start + PAUSE
DoEvents
Loop"
I've tried breaking the code execution and going into the debugger, to find that the "start" value can mysteriously be much bigger than "Timer", even though start is re-declared in every iteration of the loop before going into the while loop above.
Even more confusing is that without restarting the code entirely, I can run the code line by line using F8, and it will magically fix itself and break out of this loop.
Can someone provide more insight into why and how this problem arises, and any possible solutions?
Thank you.
Best Regards,
Ryan
    Option Explicit
Private Const PAUSE As Integer = 5 '' Seconds for Timer to pause
Private Const INTERVAL As Integer = 5 '' 30 seconds
Private startTime As Date
Private start As Long
Public Sub DoWork()
    Dim go As Boolean
    Dim currentTime As Date
    Dim timeDiff As Long
    startTime = Now
    Do
        go = True
        start = Timer
            DoEvents
        Loop
            Dim i As Long
            Call Run_Report
            If New_Item < 1 Then
            'MsgBox "No new jobs"
            GoTo skip:
            Call delete_all
            Call runsql
'            If i = New_Item - 1 Then
'            End
'            End If
skip:
    Loop While go
    'MsgBox "Repeating work has been cancelled!"
End Sub
Replies (0)
