Re: Repeat function in AutoCAD VBA
kh.teow
kh.teow
I've written a VBA code to connect to MySQL to get information to do some calculation and drawing, and then export the results back to MySQL again.
I would like the code to run automatically on a fixed time interval without human intervention but was unsuccessful. I have tried the following:
1. Enabled the Microsoft Excel Object Library in Reference so that I could use the Excel command "Application.OnTime Now + TimeValue("00:00:01")" ;
2. Using AutoCAD Core Console with a script file that include the commands -vbaload and -vbarun, but the command returned "Unknown command "-vbaload"". My intention is to use accoreconsole.exe to run the script file and use  a Windows batch file to run an infinity loop on the accoreconsole.exe every 5 minutes.
Is there any workable way out there which is easily implemented and maintained?
Best regards,
KH Teow
norman.yuan
Well, AutoCAD core console does not support VBA, so you cannot use it with VBA code.
Using another app's feature (Excel's Application.OnTime, as you mentioned) is bad idea, to say the least.
If you have to use VBA for certain reason, VBA has built-in function - Timer, which you use to record a time period elapsed and run particular code at certain interval.
Norman Yuan
Drive CAD With Code
kh.teow
Hi Mr.Yuan,
I have tried using timer command but what it actually does is to count the amount of time that the user responded instead of counting how many seconds have passed.
What I'm looking for is something to this effect, if it's written in Windows batch file:
echo off
:loop
echo Hi, how are you?
TIMEOUT /T 5 /NOBREAK
echo off
goto loop
The objective is to check with MySQL on a fixed interval to see if there are new jobs given in the database table (of course I don't mean "hi, how are you", but I intended to run accoreconsole /s abc.scr -en US).
Could you correct me if you see anything wrong in my understanding?
Thanks a lot,
Best regards,
KH
norman.yuan
Firstly, I do not know what you need AutoCAD to do, but assume it would process one or more drawings every time a new job item is detected in your database. I'd think using AutoCAD core console would be better choice with proper notification mechanism, likely a service time of app. But that would be out of topic of this forum and beyond the question you asked here.
Regardless what exactly your business process, VBA's Timer CAN provide a way to execute VBA code in a given interval. You just need a bit programming (we are programmer here, eh?). Following code shows how to do in VBA:
Option Explicit
Private Const PAUSE As Integer = 5 '' Seconds for Timer to pause
Private Const INTERVAL As Long = 20 '' 30 seconds
Private startTime As Date
Private start As Integer
Public Sub DoWork()
    Dim go As Boolean
    Dim currentTime As Date
    Dim timeDiff As Long
    startTime = Now
    Do
        go = True
        start = Timer
        Do While Timer < start + PAUSE
            DoEvents
        Loop
        currentTime = Now
        Debug.Print currentTime
        timeDiff = DateDiff("s", startTime, currentTime)
        Debug.Print timeDiff
        If timeDiff > INTERVAL Then
            '' This is where the work is done in every a while
            '' determined by const INTERVAL, I set it for 20 seconds
            '' you can set it to 3000 (5 min)
            go = DoSomething
            If go Then startTime = Now
    Loop While go
    MsgBox "Repeating work has been cancelled!"
End Sub
Private Function DoSomething() As Boolean
    Dim msg As String
    msg = "Do work here... done." & vbCr & vbCr & _
    "Do you want to it again?"
    If MsgBox(msg, vbYesNo + vbQuestion) = vbYes Then
        DoSomething = True
    Else
        DoSomething = False
End Function
I do not think using VBA with its Timer is a very good solution to your  business need, but again, the code here is only meant to show how to use Timer to run a piece of code with given interval. Run the code and watch the immediate window for the output from Debug.Print, you can have clear sense how the code works.
Norman Yuan
Drive CAD With Code
kh.teow
Thanks Mr.Yuan for your help!
kh.teow
Hi Mr.Yuan,
To be honest, I'm not really a programmer but a mechanical engineer who has had a term of training in coding Turbo Pascel some 25 years back. The line that saved the day was:
Private StartTime as date
 from here, I could just manipulate the time interval via the date function. Last time never paid attention to any date function as most of the coding was done for non-business related process, and date was rarely used as a reference. I know it must have looked stupid on my side to have missed out such a basic thing but then again, what can I say? 🙂
Thanks for you help!
