I'm just getting started in VBA programming.
I want to plot all the Layouts in a PDF File in a certain path.
example: I have 4 Layouts and I want to plot them in a single PDF file.
I hope you can help me
That's quite a common request. I would first do a search of this forum for sample code.
Dim ruta As String
ruta = "C:\UTILITARIOS\"
Dim layo As AcadLayout
For Each layo In ThisDrawing.Layouts
If layo.Name <> "Model" Then
ThisDrawing.ActiveLayout = layo
'CONFIGURACION DE HOJA PARA EL PLOTEO================
layo.RefreshPlotDeviceInfo
layo.ConfigName = "DWG to PDF.pc3"
layo.PlotRotation = ac0degrees
layo.StandardScale = acScaleToFit
layo.StyleSheet = "acad.ctb"
layo.PlotType = acLayout
ThisDrawing.Regen acAllViewports
Dim nombre As String
nombre = ruta & layo.Name & ".pdf"
ThisDrawing.Plot.PlotToFile (nombre)
Next layo
you didn't say if you were able to get this to work. You would probably need to set BACKGROUNDPLOT to off. Also, VBA doesn't have a way to plot multiple layouts directly to file as one pdf. You will need to get access to a pdf library and use it's api to import all the pages into one file.
