Pause Autocad Screen update
jalal.mousa
jalal.mousa
Is there a way to pause Autocad screen updating while code running similar to  Application.Interactive
'Code Start
'pause screen update
Application.Interactive = False
'do things
'reactivate screen update
Application.Interactive = True
ed57gmc
What are you trying to do? You don't show any code. If you post code, use the </> button.
Ed
How to post your code.
jalal.mousa
Public Function JointPolyline(ents)
Dim TReg As Variant
Dim i As Long
Dim cuts As Long
 Dim oSS() As AcadEntity
 Dim CutL As Variant
If TypeOf TReg Is AcadRegion Then
	ents = TReg.Explode()
end if
cuts = UBound(ents)
ReDim Preserve oSS(0 To cuts) As AcadEntity
For Each CutL In ents
	 Set oSS(i) = MyDWG.ModelSpace.item(MyDWG.ModelSpace.Count - 1 - i)
	i = i + 1
 Next CutL
 'add plines to group
        Tgroup.AppendItems oSS
        Dim GRname As String
        GRname = Tgroup.Name
         ' using SendCommand method with Group
        MyDWG.SendCommand "J" & vbCr & "G" & vbCr & GRname & vbCr & vbCr
        ' deleting group and clearing selection set
        Tgroup.Delete
        'sset.Clear
   Dim TempTile As AcadLWPolyline
   Set TempTile = MyDWG.ModelSpace.item(MyDWG.ModelSpace.Count - 1)
   TempTile.closed = True
End Sub
Hi Ed,
i attached partial code (hope nothing is missed) , i notice that send command MyDWG.SendCommand "J" & vbCr & "G" & vbCr & GRname & vbCr & vbCr takes more time to join lines (based on API using point), before i used join method by joininig points similar to your proposal in my previous questions by using start and end point but encounter issues as some pointes were acting as start or End  which create mistakes once lines were connected, to avoid checking start or end order i found joining will work easier but slower
jalal.mousa
Hi Ed,
I found solution while i was searching for similar cases
it was solved by you back in 2021
Solved: Re: Turn off redraw - Autodesk Community - AutoCAD
