VBA
Discuss AutoCAD ActiveX and VBA (Visual Basic for Applications) questions here.
Multiple selection of objects and their layers
1 REPLY 1
ah_4032
166 Views, 1 Reply
I want to filter my selection to filter text or mtext object in layer1 and filter polylines objects in layer2 by vba.
1 REPLY 1
grobnik
in reply to: ah_4032
@ah_4032 I suggest first of all to look inside the forum, you can find a lot of examples.
As second issue look at https://help.autodesk.com/view/ACDLT/2024/ENU/?guid=GUID-A1A6DB80-A730-45D1-B035-331F549E9667
Where is indicated the Logical operator use, as you required "TEXT or MTEXT" and "POLYLINES" on layer 2
Sub Ch4_FilterBlueCircleOnLayer0()
  Dim sstext As AcadSelectionSet
  Dim FilterType(1) As Integer
  Dim FilterData(1) As Variant
  Set sstext = ThisDrawing.SelectionSets.Add("SS4")
  FilterType(0) = 0
  FilterData(0) = "LWPolyline"
  FilterType(1) = 8
  FilterData(1) = "2"
  sstext.SelectOnScreen FilterType, FilterData
End Sub
AutoCAD Inside the Factory
