Limited number of users can load VBA project (dvb) from network folder
If we (sensibly) place our .dvb files on the network in a common folder,
we've noticed that only about a dozen users can load the files. Any users
accessing the file after the first dozen or so get nothing. As a workaround
we're pushing our DVBs to the local workstations.
Has anyone else encountered this problem? Any solution? I'd be curious to
know Autodesk's wisdom?
Trevor Taylor
Zimmer · Gunsul · Frasca Partnership
[email protected]
(remove hat to reply)
Trevor,
I had this problem before and to work around it, I generate a code that would copy the .dvb file to the local machine and run it from there. When the program is finished, I simply delete it. I do this with xml reference files as well and it speeds up the loading time also, at least for me it does.
But check out the post below, I think it might relate to what you're looking for:
http://discussion.autodesk.com/[email protected]@.f174e89#1
[email protected]
Hey Trevor!
Hope things are going well at the new job. This is a known and heavily
discussed topic. I'm not sure if Autodesk documents it but the general
411 is that only 16 to 20 simulaneous users can access a network dvb.
Yours is the first where the limit is less than 16 that I have run
across. Search the ng for more info.
Mike
___________________________
Mike Tuersley
AutoCAD Clinic
Rand IMAGINiT Technologies
In 2004 this is solved. But until then you have to work around this
limitation as suggested.
Best Regards, Jimmy B
CAD and Database Developer Manager at www.pharmadule-emtunga.com
Take a look at the trial version of SmartPurger (now for AutoCAD 2004) or
download some freeware at www.jtbworld.com
More on AutoCAD 2004;
www.jtbworld.com/autocad2004.htm
www.jtbworld.com/autocad2004tips.htm
"Trevor Taylor" wrote in message
news:[email protected]...
workaround
to
> Trevor Taylor
> [email protected]
