Layer-color
Layer-color
suparhigh12345
Layer-color
suparhigh12345
Hello, how to set autocad to "ByLayer" before any drawings. Unfortunatly I was not able to accomplish that simple task on my own. Is this possible?
norman.yuan
ThisDrawing.SetVariable "CECOLOR", "BYLAYER"
Norman Yuan
Drive CAD With Code
Ed__Jobe
Since you want to do this 'before drawings', it's worth mentioning that you can create a dvb called acad.dvb and if you put it in the search file path, it will load automatically at startup. Then if you have a public sub called AcadStarup in this dvb, it will run at startup. Here you can set your variables.
Alternatively, you can set the variable value you want in SYSVARMONITOR and it will notify you if it has changed.
Ed
How to post your code.
