Insert several blocks with vba
Message 1 of 10
Hi I have this code working ok, but I want to insert several more blocks can anyone help
Thank you
Dim blockObj As AcadBlock
Dim insertionPnt(0 To 2) As Double
Dim blockRefObj As AcadBlockReference
' Insert the block
insertionPnt(0) = Val(TextBox21.Text): insertionPnt(1) = Val(TextBox28.Text): insertionPnt(2) = 0
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "T2", 1#, 1#, 1#, 0)
Accepted solutions (3)
Replies (9)
Message 2 of 10
grobnik
@Anonymous
the question could be stupid but all the same block name and all in the same position ?.
Could be simple to create a loop count with total amount of blocks to insert and repeat insertion command, or if you want to shift you can insert in the loop a coordinate constant shift.
May be so simply ? I guess no.
For X= 1 to 3 'you can insert a new textbox with amount of blocks
'if you want to shift by X
N=0
insertionPnt(0)=insertionPnt(0)+ N ' shift value
N=N+5 'VALUE to INCREASE for X coordinate shifting
Next
Message 3 of 10
Hi
Apologies for not enough detail, The textboxes are in the userform  x and y
The block I am inserting is T2 its the same for each of the insertions but in different positions
Below is what I have but not working?
Dim insertionPnt(0 To 😎 As Double
' Insert the blocks
insertionPnt(0) = Val(TextBox20.Text): insertionPnt(1) = Val(TextBox28.Text): insertionPnt(2) = 0
insertionPnt(3) = Val(TextBox21.Text): insertionPnt(4) = Val(TextBox29.Text): insertionPnt(5) = 0
insertionPnt(6) = Val(TextBox22.Text): insertionPnt(7) = Val(TextBox30.Text): insertionPnt(8) =
Thanks for your help Chris
Message 4 of 10
grobnik
@Anonymous
I guess that the issue is inside the coordinates array because insertblock is expecting an array with 3 points X, Y, and Z, not 7 or eight.
I'll investigate more, however you can put in an array the value of first couple of textbox and third value to 0 if Z coord is 0, insert block, put the second couple and insert block with new coords array name coming from other text box, and so on.
Dim insertionPnt1(0 To 2) As Double
Dim insertionPnt2(0 To 2) As Double
insertionPnt1(0) = Val(TextBox21.Text): insertionPnt1(1) = Val(TextBox29.Text): insertionPnt1(2) = 0
insertionPnt2(0) = Val(TextBox22.Text): insertionPnt2(1) = Val(TextBox30.Text): insertionPnt2(2)=0
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt1, "T2", 1#, 1#, 1#, 0)
Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt2, "T2", 1#, 1#, 1#, 0)
Try and let me know
Message 5 of 10
Hi
Thank you very much it seems to be working ok is it ok to accept this as a solution
Message 6 of 10
Hi
One thing I have noticed, if there is no entry into text boxes the object T2 is placed in drawing at 0,0
have you any idea how that can happen.
Regards
Message 7 of 10
grobnik
Hi, @Anonymous
I just show you the method, of course, the insertion point it's 0,0,0 because coming from a numeric conversion of an empty box text value, the array will be 0,0,0 and block will be inserted in that coordinate 0,0,0.
I suggest to insert a command button side each group of coordinates text boxes in the form and insert in own event Sub the insertion block code, checking, BEFORE INSERTING BLOCK, if coordinates of X and Y are > than 0.
Let me know
Regards
Message 8 of 10
Ed__Jobe
@Anonymous wrote:
Hi
Regards
What do you expect to happen? Do you want to prevent users from clicking insert when the text box is empty? Give the text box a default value.
Ed
How to post your code.
Message 9 of 10
grobnik
@Anonymous
Here an example of what I'm saying, you can replicate the code on command button for 2nd block and so on
Private Sub CommandButton1_Click()
Dim insertionPnt(2) As Double ' this part should be moved inside formload event and declared as Global in order to avoid a ridimension, or use ReDim command.
If UserForm1.TextBox1.Value <> "" Then
    insertionPnt(0) = Val(TextBox1.Text): insertionPnt(1) = Val(TextBox2.Text): insertionPnt(2) = 0
ElseIf UserForm1.TextBox1.Value = "" Then
    MsgBox "Insert the coordinates Value in TextBox"
End Sub
Message 10 of 10
Hi Thank you very much you have solved the issue for me
Chris
