VBA code (i.e. via AutoCAD COM API) does not know if an anonymous block reference is an entity array or not. So, in the workflow of your VBA code execution, you should somehow make sure the target anonymous block reference is indeed an entity array bore you use code to explode it.
Now assume you are sure the block reference to be exploded is entity array, the you simply explode the entity array, and then explode each "element" entity of the obtained entities of the first explosion. That is because when AutoCAD creates entity array, it first make the element entity into an anonymous block, and then generate all elements according to array parameters (rows, columns, space distance...) as block reference of that "element" anonymous block definition; then AutoCAD place all the elements (block references) into anther anonymous block as entity array. So, after 2 round explosions (first round explodes the entity array itself, once; the second round explodes each of the element block references generated from the first round).
You need to remember, Explode() method execution is different from command Explode: it returns an array of entities from the block reference being exploded, BUT, the original block reference itself is not affected. It is up to your code to decide when to do with the entities generated by the explosion: erase them, move them, or leave them at the place (that is what you described: "... creates a bunch of circle overlap...).
In your code, you can access the circles' data (center point) and then erase them.
The other way to obtain the circle data is to go to the entity array's anonymous block definition, and loop through the entity (element block reference) in it, and for each element, go to its anonymous block definition again, loop though its element, which is circle, of course. Based on block reference's geometric transformation, you can calculate where each circle's center point is according to the entity array's position.
