How to create a New Microsoft Excel Worksheet file
m09366023695
m09366023695
I want to create a New Microsoft Excel Worksheet file.
Call createFile("c:\myproject\file.xlsx")
Function createFile(path)
Dim fso As Object
Set fso = CreateObject("Scripting.FileSystemObject")
Dim Fileout As Object
If FileExists(path) Then
Else
Set Fileout = fso.CreateTextFile(path, True, True)
Fileout.Write "your string goes 54545645464here"
Fileout.Close
End Function
but it create file but I cannot open it.
norman.yuan
You cannot assume an file for a specific application (*.xls/*.xlsx file of Excel application) is a plain text file. Theoretically, only Excel (and some Excel compatible apps) can generate/save a *.xls/*.xlsx file.
However, Excel can open and save data from/to many other formats. In your case, depending on the purpose of using the AutoCAD in the Excel, you can choose either use COM automation to run Excel to open a new XLS/XLSX file and send data to it. But if you do not care to format the data in the worksheet for presenting purpose and only use it for simple data storage, you can simply save the data as CSV file (a plain text file with "," as delimiter. Excel can happily read/save CSV file. Better yet, with CSV data format, in your Acad VBA code, you do not need to run Excel at all.
Norman Yuan
Drive CAD With Code
